Where is the "paddle" shift on the 01 GS430?
Originally Posted by rominl
i have had acura and now the gs4, i definitely prefer the eshift. my hands stay on the wheel when making sharp turns and shifting. taking hands off the steering wheel to the shifter is not as good
I dunno, when I had my 240sx, I never had any problems steering with one hand and shifting with the other. I dunno if I learned it while drifting or I'm just too lazy to lift my right hand off the stick...
Originally Posted by jskim9
what do you do when your steering wheel turns over 270 degrees? :
Good point
I definitely prefer using Honda's type shifter over the e-shift. If those guys with manual transmission are able to steer with one hand and shift with the other, then i can drive Honda's tranny like that
Auto tranny shifting?????
This may seem like a dumb question to some, but coming from a Range I never shifted gears while driving for racing (for obvious reasons.) How exactly would shift thru gears on an auto tranny (non Tiptronic) i.e. gs430 and would it mess up the tranny??? Thanx
exclusive matchup
Originally Posted by GSteg
Good point
shifting in the middle of a turn when you are doing 270 degree, that's a drastic change of force and such during the turn. it's hard to control
Originally Posted by TheSupe87
anybody got any feedback?
I run it on e-shift all the time. If you let it stay in 5th gear, it will drive just like it does in "D" mode, shifting by itself at the proper time. Then when I want to have a little more control, I bump it down to the lower gears. Sometimes I do this to use engine braking as well, like I used to do in a manual transmission car.
Originally Posted by opmredwing
So did I read correctly that a 00 GS4 with the paddle shift cannot have the wood steering wheel?
see if you love it while you're taking a sharp turn... I prefer Honda's "Craptronic" in that respect, since you shift up and down with the auto stick. But Honda's auto trannies are as fun as a 1991 Ford Tempo.
for some reason my gs 4 shifts kinda hard when using the m mode but i gotta play around with it some more, still waiting for my first race in this thing seems like no one wants to even try on my way home with the tl type s i had some punk in a civic try to race me, by the time i hit it into third the car was at like 70 mph and the civic was a long ways back in my rearview
as for shifting thru a turn who tought you how to drive i thought it was understood what others have said here about keeping your line and half way thru accelerate your way out.
i personally don't use my M shift on the 430 often. Maybe once in awhile just to get the feeling.
but if you have a 430 and you want to be able to take corners and stuff... just get yourself some sways, stb, and lsd and you should be able to drift the GS.
i saw a guy with a GS430 who had the 3.76 LSD drift around a corner perfectly. it was hotness.
I shift my 430 manually all the time. I can shift with right hand and change radio stations with my left thumb at same time, around a turn makes the car feel way faster and lets the gears stretch out .it does shift a little harder when you do it manually, which is fine with me. the main thing to remember when shifting yourself is to do it early because there is a delay and you'll nail the rev limiter if you don't time it right.
wheel
yes if you get the 01+ gs300 wheel, you will need airbag too
so will the wheel work with the eshift on my 400? and was that a yes I do need an RX330 airbag aswell.....something about the way the air bag plugs into the car..?
Originally Posted by svt5150
Yes, you are correct. Ask Henry (rominl) or search for it. An easier way would be to contach American Stitches and have them do a wood wheel for you. Runs about $400.
Do you have any pics of what this company's work looks like?
