How do I remove the trunk bar for the chrome replacement?
tried searching the site for a thread but couldnt find anything useful.
bought a chrome trunk bar and want to take the stock one off, what would be the best way to go about this? should i pop the trunk liner and try pushing the old one out from there? or should i use a thin screw driver and a rag and pry the old one off? it came with instructions but they are in japanese
I did this mod couple of weeks ago. Very simple.
Just simply remove the inner trunk lid liner. There are two or four (can't remember) 10mm nuts to remove and then just simply push the oem bar out. Kind of snaps out of place.
Then basically reverse the steps for installation of the new one. You will need the bolts from the oem bar for installation of the new one.
Just be patient and good luck.
What he said I just did it yesterday. You will have to remove about 20 of those plastic hold down devices. If you don't have one of those slotted removal tools, I would go to Pep Boys, or what ever, and pick one up. It will make removing those very easy. Then basically you take that whole thing out and you will remove 4 10mm bolts. Pop it out and reverse the process to put the new one on. The hardest part is the emergency release handle trim does not want to let go. Good luck. It will look sweet.
Originally Posted by GILLEXUS
e-diddy & TexasGS,
Any pointers on getting the emergency release handle trim off, I remeber last year Itried to take that off to check the wiring I about broke so I stopped
thanks for the tips, just installed it in less than 10 min
my cover was cut around the pull handle as well and that wasnt a problem at all...also taking those tabs off was easy as hell and i didnt need any special tools.
my only ? is those two lights, they are not flush against the piece correct? they have a slight curve to them and they are not flush at either end but are in the center
Yea, mine looks like that as well. I notice it looked like that on the OEM trunk bar as well. I guess that is just the way it is
