Steering wheel shakes! When putting on 20inches! Help!
#31
Originally Posted by OutlawTita
To completely eliminate this problem you have to spin balance each wheel while it is on the car. I paid $15 per wheel and now there is zero shimmy at any speed.
But as far as this subject in general, been there done that. There's a BUNCH of factors involved.
But non-hubcentric rims, even with rings, particularly if big and heavy and not a high end brand, are likely to cause shaking. A $500 20" cast 'generic' rim is just not going to be as evenly balanced (WITHOUT WEIGHTS) as a high quality forged $1000 rim.
I had 'generic' 18's that I couldn't get completely smooth despite adding rings, balancing, aligning, new tires, etc. Sure there's been other 'solutions' since then (steering rack, bushings, etc.) but they were obviously not the issue for me because when I went to quality hub-centric 19" rims I have NO balance problems - smooth at all speeds.
So there's no silver bullet solution. If you have a tight budget for rims, there's a fair chance you're going to have vibrations at one speed or another.
#32
Yes, an on car high speed balance is the best balance you can get because it takes the suspension and other components into account. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
#33
Originally Posted by STONER
How bout the vibration with the stockers though?
Bad balance
Bad alignment
Bad tires (even new ones could be out of round - or uneven wear)
Bent rims
Bad suspension
Bad steering
Bad brakes
(Usually check in that order)
#34
This topic has been discussed half to death in the short time that I've been here. There are a number of possible causes, and at least as many recommended solutions. The fact is, that there is a problem with the GS causing a vibration on MANY vehicles at or around 60 mph. Both rominl and lexforlife have done the Daizen bushing replacement, and that seems to be the best solution to date. You can do a search on that as well. I have the vibration and every couple of weeks I loosen and retighten the lugs in a star pattern to torque spec. I also had the lower ball joints replaced (because they were bad, not as a solution to the vibration). I'm saving my pennies for the bushing replacement labor cost, but will probably wait until I get rims in the spring. I don't think I need it before winter here in VA.
Good Luck
Good Luck
as stoner quoted above , the daizen bushing replacement is the way... the castor.or strut rod arm as some call it has a bushing within that is the worst design for perf .. it has loads of play built into into for luxury.. when the bushing flexs it allows the arm to allow for movement which allows the steering knuckle to move while in motion.. because we have no castor adjustment, this bushing can throw your alignment settings off while driving and your castor also affects your camber , toe and sai. this explains why sometimes you have shimmy and sometimes its almost perfect.. thats not a balance issue nor alignment.. it changes depending on road surface and how the bushing is moving within the arm..
since doing the swap just like rominl , i am 99.9% vibration and shimmy free (the 1% will always be there with aftermarket larger stuff ).. when going 19-20 in that creates a contact patch area about 30% larger then 17in did and the susp was never designed for that so it will accelerate and amplify the disitortion you feel
get the daizen kit , bite the bullet and do the upgrade , and drive happy
#35
romini I don't know how they were balanced - just that I've had them balanced at 2 different tire shops - I guess that I thought all types of balancing were the same.
Stoner I do have the full daizen sway bars including bushings - I got the kit about 6 months ago so I don't know if they're the bushings you're referring to or not.
#36
#37
Originally Posted by rominl
how were the wheels balanced? on hunter machines with road force analysis? that's the key
There are lots of different sizes out there so how do I figure out what size hub ring I need. I went to Discount Tire and they didn't have the right size. I went into a wheel retailer and they didn't either. I called the wheel manufacturer and they were no help except to tell me the bore size of my rims. I called Lexus of Austin to find out my hub size and the guy in the parts dept. had no idea. I am at my wits end. What do I need to do? I have searched all over CL for the answer and cannot find the answers anywhere.
Please help.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
thank you,
Carle
gamma113
11-14-22 09:12 AM
