Look what greeted me when I got home!!
#35
REmove all of the fender lining to get some more clearance. I shaved inside the fender tabs. Do a search and you will see. If push comes to shove, just give your car some more negative camber so that it will go in more. About 2.75 is great.
#36
#37
Car looks awesome, congrats.
About rubbing with fat 19's and spring/shock setup - I had this in front with L-Tuned springs/shocks when going over big bumps at speed. I flattened (HAMMERED) a metal 'tab' that comes down from the top of the wheel well and that helped some, but the problem went away when I went to coilovers.
How high the ride is isn't the whole issue because my ride on coilovers is a lot lower than on L-Tuned springs/shocks and I have no rubbing at all.
Cleanshots
SC- 1st Gen (1992-2000)
24
05-11-14 06:10 PM
Stormforge
12-24-10 11:07 PM
Manaray
Wheels, Tires & Brakes Forum
01-19-03 05:01 PM
