Smoky 11's or One wheeler peeler?
Old 10-18-05, 08:52 PM
Stage3
Stage3's Avatar
Default Smoky 11's or One wheeler peeler?
I've been wondering ... those that have been brazen enough to pull of some smoky burnout's in their GS's. Do you lay down the big smoky 11's after the VSC is turned off, or is it a One wheeler peeler show??? There has been some sand outside of my driveway do to a neighbor building a pool, and I have been having a little "fun" with the VSC off. I feel the car going sideways, but im guessing its do mostly to the sand. Anyone know???
Old 10-18-05, 10:00 PM
rominl
exclusive matchup
rominl's Avatar
i have lsd so i have 11 all the time. actually on a good gnd surface with same traction left and right, even without lsd you should have 11. if you are on bad traction area, then likely there will be just one
Old 10-18-05, 10:28 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,279 Likes on 1,385 Posts
Without LSD (unless you're lucky like Henry says with both wheels hooking because timing is just right) it's just like the Highlander says.
There can be only one!
Attached Thumbnails Smoky 11's or One wheeler peeler?-highlander002_connor.jpg
Old 10-18-05, 10:38 PM
rominl
exclusive matchup
rominl's Avatar
hahah dave, go back to work. it's too late for you
Old 10-19-05, 06:32 AM
chuckb
chuckb's Avatar
if you are pointing perfectly straight, you can get both tires to spin at same time.(I did it on my driveway once )
btw-never heard it called a smokey 11
Old 10-19-05, 08:32 AM
Dx3
Dx3's Avatar
As Henry said - with the LSD, TC and VB upgrade my car will keep burning out until I lay off the gas. Lots of fun - my tires don't like it though!!
Jonny
Old 10-19-05, 09:30 AM
oohpapi44
oohpapi44's Avatar
I've done clean 11's in my stock 430, one line a little darker than the other, lines were appox 50 ft or so.
Old 10-19-05, 11:52 AM
Stage3
Stage3's Avatar
You need to watch Top Gear more often!!!! (when they put it back on the air that is)
Old 10-19-05, 02:44 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
LOL dave, a simple no would have worked
Old 10-19-05, 06:18 PM
Burton
Burton's Avatar
Here is your answer
Burnout
Old 10-19-05, 08:15 PM
GSXLEX
GSXLEX's Avatar
OK..so in stock form the GS can lay it down???What technique is used ie.just punch it,rev neutral and slam drive(I hope not)..Only car Ive ever laid rubber in was my Maxima and that was easy with a stick..but automatic
Old 10-19-05, 08:47 PM
e-man
e-man's Avatar
I'm assuming that you have to brake torque the car in order to spin the tires on straight line acceleration.
Old 10-19-05, 10:07 PM
rominl
exclusive matchup
rominl's Avatar
if you want it for sure, turn off vsc, power brake, floor it, and let go of teh brakes
make sure there are no cops around
LexFather
08-04-06 06:03 PM
alsilverbullet
Performance
67
07-14-05 07:59 AM
SilverLexo
Performance
12-21-03 10:06 AM
///MDex
05-31-02 04:50 AM
gwu128
01-23-02 04:45 PM
Quick Reply: Smoky 11's or One wheeler peeler?
