When you replacing your timing belt, do you replace you water pump at the same time?
I will need to replace my timing belt in the coming weeks, do I need to change the water pump like most people said? What is others experience? I call Longo Lexus and the guys said that it depends. BTW, he quote me $600 for replacing the timing belt and about $950 with the belt and the 90K service combine, is that a good deal?
Thanks
Thanks
My father's theory is that you wait until the water pump begins to leak, then replace the timing belt...but that's too much risk for most people.
So, high mileage GS drivers:
What is the likelihood of the water pump needing replacement before 120k miles? 150k miles? 180k miles?
Thanks
Thanks
yeah my car is about 53k and i need to change my belts too how much would it be ? i have the hook up @ toyota certified but shuold i let him do it or bring it to lexus dealer?
53 k miles and you need to change the belts? watcha do spray em with anti-freeze?. The recommended milage for changing a timing belt in the lexus repair manual is actually outdated, it was carried over from the pervious gen gs and the vvt-i was not a factor. With vvt-i the timing belt is stressed more.
no no I was making a joke kinda, anti-freeze is known to eat through rubber but anyway the screetching noise is your serpentine belt and at 53 k miles you have another 7 k to go before you actually enter the timing belt changing phase. Unless you want to change them now and sleep easy go ahead but you can still get at least 30 k of them, most likely more.
