how high are you?(suspension)
how high is the bottom of your fenders from the ground? the distance I'm referring to is shown below.
I just measured mine as a baseline before the coils are installed. I'm curious what others height is with different wheel/suspension combos. here are my measurements from bottom of fender trim. here are my heights, stock w/245-40-18s.
mods, can this please stay in main 2nd gen forum for a while?
I'm 26 1/4" all around with 245/35/20 which is 1" taller than stock. This is probably the lowest setting you can have for 20's. You'll hit the inside wheel liner if you go even lower.
Location: A middle sized town in the middle of the Midwest
Just a thought. Wouldn't just the slightest change in elevation of the ground, change the measurement? I could be wrong, but it just seems like it would.
But I guess that would be the outcome regaurdless of what points you measure at.
Hmmmm....................interesting.
I have 26 3/4" all around with the exception of the passenger side rear which is 27 1/4".
This is with the Tein CS on 245/35/20 all around. This is also with a full tank of gas.
Should I look into this or is it normal for one of the measurements to bee off like that ?
Originally Posted by aloha03gs
in terms of wheel gap...i have 1/2 finger in the front and zero (even gap) on the rear
Just got in from measuring, '01 GS 430 with 215X60 studded snow all the way around on stock silver 6 spokes. Suspension unknown, assumed stock. 27 1/4 front, 26 3/4 rear with just under a half a tank of gas.
Originally Posted by GSXLEX
Half tank...28 in.Front..27.5 in..Rear
19'stagerred 245/40/19..275/35/19
25 7/8" front
26" rear
(full tank)
(no rubbing whatsoever)
Originally Posted by callaghan.
im sorta low...
thanks for the measurements everyone else, keep em coming.
