Wiper hitting hood-
Guest
Posts: n/a
Wiper hitting hood-
I searched and found this, so I'm reporting my first experience with this problem.
I'll try the solution listed here -
https://www.clublexus.com/forums/sho...ighlight=wiper
Just looking at the pics you provided it appears that the hood is not aligned properly. Could just be an illusion, but the gap looks larger in one pic than the other. More than likely it's the loose nut as described in your link.
If you forget and try to open the hood while the wipers are up and away from the glass like when you are changing blades this can happen.
akshunj
12-29-15 05:43 PM
FMitha
07-23-11 12:20 PM
