Gs400 won't always start
Sometimes when I go to start the GS, the car won't start. I get nothing when I turn the key, radio works, but car won't start. If I take the key out and put it back in it seems to start right up. Anybody else having this problem? Just started recently. Also I have the Remote Start from Luxury Motorworks and it is not working either. I have it uninstalled right now too, but I was wondering if this could be a cause for any problelms? I am waiting for the newer version of the Remote Start to come out and I will be have it again!!! Yeah
But really has anybody else had this problem?
I agree..sounds like the starter. I had the same symptoms. You'll have good start days and bad start days depending on temperature from what I've experienced. It will eventually get to the point where you're clicking the starter for about a minute to finally start. Some have DIY here on CL, save you alot on labor...cost me $1200 at the dealer.
Im noticing on my gs3 now that it is getting colder outside its starting very weak... When January comes and its 20 degrees outside i think im going to have a problem...
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Originally Posted by JMgs300
Im noticing on my gs3 now that it is getting colder outside its starting very weak... When January comes and its 20 degrees outside i think im going to have a problem... ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
The One
Originally Posted by whytry
Thanks, I can't believe I did not even think of that.. I overlooked the most obvious thing on the ride, and assumed it was the remote start because I have been having problems with it too since I installed it.....
Former Vendor
i had the same issue with my gs3. come out - system is dead. nothing. get the click click click click - nothing...
turns out - needed a new battery and a new battery cable. $120 for the red top battery (3 yr warranty is better than the 1 yr yellow top) and $30 for the battery cable.
Keep in mind man - it doesn't take something huge to render your 50k car useless. Maybe it's something small like a battery cable.
c.
c.
The One
THX Neo, not sure on the battery in the car. Maybe I will replace it to start, cheaper.... Does an Optima fit right in? Or is modification needed....
There are more detail writeups on the Optimas on CL too.
