To all who have had to replace the notorious STARTER on GS4!
Well as some may know my starter is kickin the bucket just like it seems to with many others on here. And the consensus is that 7 years is a long time for a starter to last...but I never had a problem with the starter on the two 15 year old cars I used to drive. Anyways, I digress...So the dealership (not Lexus) I bought the car from three weeks ago is giving me a deal to change the starter for $650 (they said it was their cost, Lexus quoted me $1154). But I have a very inclined friend who insists that if we just get into the starter it probably just needs a good micropolish and graphite lubing to the Bendex (this is mechanic talk thats over my head).
Anyways, my question is, if I do go the route of the dealership, what other birds can I kill while they're in there with the intake manifold off? I want to get as much done as possible to get it out of the way. The car has 101,000 miles on it and Lexus did do the big 90K service. Secondly, has anyone else on here just done the polish and lube to the starter and had it work fine after that? I was gonna buy some wheels from Lexism but now this is puttin a damper on things. Thanks all for any help.
If your friend is truly mechanically inclined AND knows what he's getting into AND has the shop manuals for your car, then do it. I consider myself very mechanically inclined (rebuilt and replaced couple of engines, changed clutches, redid brakes, etc., all on previous cars). I just got shop manuals for the GS, and was floored by the complexity of these cars--especially the electronics. I don't want to discourage your friend, but just ensure that he's up to the task. Good luck.
JB
JB
Do a search and you'll find that member chuckb had rebuilt his too. He bought the starter rebuild kit from Toyota I believe. If you have the technical ability and time you'll save a bundle.
well, you need to know what are you doing first. Basically you need to drain the coolant and disconnect the hoses, unplug all sensor that is in the way, take off intake, and vacuum hoses, then you will eventually get to take off the intake maniford. rebuilting the starter is simple, just replacing the center copper piece.
It is a lot of work, take me and my friend for 5 hours to complete. But hell, if Lexus is charging over 1000 to do it, I would do it myself.
Good luck.
Good luck.
I posted a request on the engine forum about a starter diagram, because I am going to replace the starter myself.
If any of you have it scanned, can you post it or send it to me at cslw33@yahoo.com
That would save me a lot of time.
Thanks!
Thanks!
Thanks!
Thanks!
![](https://www.clublexus.com/gallery/data/500/medium/starter-1.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/starter-3.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/starter-4.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/starter-5.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/starter-6.jpg)
Rickna (12-20-18)
I don't know how different the starters are, but my es was just click sometimes when you turn key, I replaced solenoid contacts and sanded plunger, worked like a champ. $15 for the contacts from toyota.
this showed me how......
http://www.off-road.com/toyota/tech/starter/
wow, just finding out for the first time that the starter sit below the intake manifold... that's just about the most retarded thing I've ever seen Toyota do. That's something you'd expect from a European car, didn't think Toyota designers would be so thoughtless. What next? Put the air filter in your dash board and you have to take the entire dash and steering wheel off to replace that? I'm so dissappointed that they couldn't place the starter in front of the engine, like every other longitudinally engine that I can think of... That's just
. Is the GS300 engine that way too? Man, after touting to everyone of Toyota's engineering prowess....
. Is the GS300 engine that way too? Man, after touting to everyone of Toyota's engineering prowess.... ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Oh, and as for the air filter... VW Beetles already have the air filter in the dash. The allergy filter is in the dash and you have to take the top part of the dash apart to get it out... Crazy Germans...
Originally Posted by Stage3
you gotta be kidding!!!! It costs $1100+ to change a starter on a GS??????? WTF? I remember doing one on a Jetta... It took a total of 20 minutes. Although that's a FWD car...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
it only took me 20 minutes to remove starter from my ES too, the GS is just different.
