Brake disc
shane
make sure you get the aristo s300 version(this is the non-turbo) one. the rotor would be the same as supra non-turbo, and it will fit the stock gs300/400 we have here.
do you mind if i ask any particular reason you are doing this? i assume you can get a good deal on the aristo rotor?
will
will
Guest
Posts: n/a
Hi Will,
Thanks for your quick reply. Much appreciated.
I haven't asked Lexus the price their brake rotors, but I figure it won't be cheap. Hence, I think I will be better off getting the rotors from Endless or Project U because they are probably either just as expensive or cheaper than the Lexus rotors. Endless and Project U definitely make rotor for Aristo (Turbo) and I am hoping they are the same size as the GS300. From memory, the brakes on Aristo Turbo is the same as those on GS300, however, I am not 100% sure. I want to find out for sure before I ask my friend in Japan to get them for me.
Shane
Shane
