Rookie here; need help accessing side markers, and foglamps to check/replace
I have a silver '98 GS300, purchased in January '05
Currently, I have the following set up regarding lights:
Aftermarket HID's
The two smaller headlamps are not the typical yellowish halogen lamps, but bluish in color
Clear side markers, bulbs are blue, beam white
Clear fog lamps, but projects a yellow beam
I can take no credit for the nice set up, as the previous owner did all this
The guy moved to Singapore, so it will be difficult to contact him
Which panels do I remove to access the side markers, and foglamps?
I could figure this all out, but I work 7 days a week.
Any help would be appreciated
Thanks in advance!
Aftermarket HID's
Thanks in advance!
yes....go through the fogs is the best way!!
Originally Posted by lalexusgs
Fogs are very easy to remove - each one has just two screws to take off. Once you remove your fogs, you can get to your side markers through fogs' holes.
BilluAwan
Lighting
18
04-06-09 06:01 AM
