VSC issues
I got a 99 GS300 and intermittedly the VSC light comes on when driving. when this happens the car is sluggish taking off but if you turn the car off/on. it will drive fine. what could the problem be
Originally Posted by morris
The reason I ask is because under hard acceleration or hard cornering that is normal behaviour. It kills power before you get the car in to a situation whree it is loosing traction or about to be out of control
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
Originally Posted by rysc
when this happens you can't turn it off. he just got to car so he's going to take it back to the dealer.
There are three times when the light lights up.
1. Test .. when you trun ignition to on [most drivers .. not CL members .. never look at the indicators and simply twist the key to start
2. When the VSC kicks in [it senses variation in front/back wheel rpm] and cuts throttle and selective brakes are applied. Once things get back to normal the light goes off. As pointed out this condition happens during agressive driving/loss of traction .. ice/slick/mud/poor_tires etc.
3. When there is a system failure. Here the light remains lit. It can be intermittent on an off, as the system may cycle to "all good" and "problem".
Hope this helps.
salim
Hope this helps.
salim
