Oil Pan Gasket
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
MP
Have you identified the source of your leak? The bottom part of the oil pan is a stamped steel, and the part it connects to is also part of the pan, but it is made of aluminum. That part gives structural rigidity to the block.
I see no reason why you can't remove the steel oil PAN without removing the engine. The aluminum part is a bit trickier. So which one is leaking?
The pan is sealed by a portion of adhesive, instead of a gasket, altogh a gasket MAY be available aftermarket.
By the way, WHICH car are you driving..GS400/430, or the 300? That makes a difference you know. The info above relates to the 400/430.
Good luck!
Good luck!
Good luck!
Good luck!
I took it to my mechanic as soon as I noticed it. They had a little trouble finding where the leak was actually coming from. They used thier telescope mirrors and from what they could see they thought it was coming from the oil pan. I was told that the oil pan was a two stage deal that required the removal of the engine to get to both sections? They also said that there are no parts needed it is only am adhesive and thats it that has to be scraped off and then resealed.
If two pieces {I am not familiar with GS3} then the only reason to open the two would be if both leak. So theoretically only one pan needs to be removed.
I have worked on the trans-pan and you would need something called "fipg" if my memory serves me right. So you take the pan off and clean both surfaces thoroughly. They reccomend non-alcohol based cleaner. lay a continues bead and in put it back in less than 15 minutes. Key to a good job is the proper troque on the pan bolts. too little => leaks ... too much=> Leaks + distorted pan surface.
Apart from that it might be worth investigating why the leak happened. Break in th fipg is one explanation. Worse it that the pan hit something on the road and is warped/cracked. No sense putting it toghther to find out that the leak still exists. Don't agree on to "put a hole lot of fipg to cover a warp/fine_crack" as it will be band-aid only.
Salim
Salim
Salim
Salim
Matt
Originally Posted by Dukespeed
Anyone know a good shop in Houston to take the GS3 to that knows alot about the car/engine?
Thanks
MP
Thanks
MP
You need some one who is going to do the job carefuly, knows the torque setting and has the torque wrench for that range.
The biggest problem I forsee is the prepardness for both outcomes .. pan ok and pan not ok.
trick: Lay butcher paper on top of a glass/mirror [flattest surface available], Lay a flash light .. turn it on, and cover with the pan. Position the light so that it tries to shine out of the suspect area. See if you can see the light.
Alternative: Put a stright edge on all four flats.
Salim
