OMG: individual throttle body 1UZ-FE???
Old 11-30-05, 10:47 AM
TexasLex
TexasLex's Avatar
Including the cams, the 8 throttle body setup would run around $4,000 NZD which is equal to approx. $2,800 USD. However, I believe a stand-alone electronic control system would also be needed which I assume is why they reference the Link system on their site. Also, I would not use their uni-filters, instead I would have a trick air distribution plenum fabricated out of aluminium to avoid sucking in underhood air. Of course you would also need to add shipping and possibly install charges to the above.
Old 11-30-05, 03:41 PM
Adam2562
Adam2562's Avatar
wuts the price of just the ITB's???? those cams wont work on our cars
Old 12-01-05, 11:29 AM
TexasLex
TexasLex's Avatar
Do a search under "1UZ-FE camshafts" and you should find several companies in Australia and NZ that make cams for our engine.
Old 12-01-05, 03:09 PM
Adam2562
Adam2562's Avatar
no trust me i've looked into it b4 they are for our engine but not the ones with vvt-i heads which our her ein the states has froma 98on as a GS atleast
Old 12-02-05, 10:07 AM
TexasLex
TexasLex's Avatar
Well don't feel too bad about it because the Camshaft Shop told me their cams would only add 15-30 hp on my 1994 1UZ-FE. At $1,500 for the cams + labor, I figured the HP/cost ratio was not good.
Old 12-02-05, 11:28 AM
Adam2562
Adam2562's Avatar
eh... 15 is on the low side but ...if it really was 20-30hp i'd do it... if i could
Old 12-02-05, 05:45 PM
TexasLex
TexasLex's Avatar
Have you emailed Kelford Cams to see if they would make a set for you?
Old 12-03-05, 07:23 AM
Adam2562
Adam2562's Avatar
no i havent... i'm only a college student.... and if when they make am.. if that means u send ur out then they regrind them... and patch on new lobes.. thats not a safe way of doing it.. not reliable... and it costs more and theres downtime i need mycar everyday its my daily.. i'mnot fortunate to have many cars.. so basically i needa kit thats mass produced so it wont hurt the pocket too much and i can install them myself..
finny76
GS F (2016-present)
06-05-19 12:09 PM
RX3302004
01-08-15 04:34 AM
funcrusher
07-15-10 04:49 PM
kikaida
10-24-09 04:50 PM
RA40
09-01-08 11:17 AM
Quick Reply: OMG: individual throttle body 1UZ-FE???
