Weapon R intake
#47
Thanks GSPOWER
Yes, hope everyone knows that tuning does take some time but over all we made and got good results pretty fast. Sorry but again we are not using the APEXI!
AS for what this chip does, well you can control RPM, take out the speed governor and much more. Can't get into too much details right now but will later on. Just have to wait until my car is finally done. tuning and dyno does take much time but its for the GS RIGHT
#48
Originally posted by y2kgs
Well, here is all the numbers as of yestherday. Sorry the chip that Weapon R is using isn't the APEXI but one that was made in Japan. My car is almost done with tuning but we are going to do one more run later on. We ran out of time given that my career isn't in the auto biz. Don't worry cause we might all have time to finish next week
These numbers are for a GS400 with 18's 275/245
Stock GS 236HP
SRT GS 249HP
Weapon R w/tunable chip 258HP but not done yet
Note that I was using a Stage II from Weapon R to run the test. Everything looks good right now so I will let you know more by next week. That is if we all have time
Stock GS 236HP
SRT GS 249HP
I am having a VERY BAD feeling about the 600 bucks I spent on the SRT HFI/ECU... Is anyone interested in a used SRT HFI/ECU?
Maybe I should demand a refund...what's SRT return policy if not fully satisfied? YEAH RIGHT looks like I just wasted 600 bucks....SIGH
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Brent
#49
Bliu.. I think you should take it easy.. HP gains are dependent on each car, not only the intake/ECU that you're installing. If y2kgs got a 13 HP gain instead of 24, that could be affected by a number of factors. The 18" rims for example. Unless they were the identical weight that the stock ones are, final HP numbers will be different. How about gasoline octane? And air density (humidity/moisture)? Also, each GS has a different history, maintenance, mileage, type of driving (soft/hard/etc.), and other factors.
Also, consider the fact that SRT is developing more "stages" for their intake ECU. There will be upgrades available - perhaps free of charge, that might surpass the Weapon-R / Apex-i combination.
There's also this: safety! There is only so far that you can push the engine in terms of timing, richness of the mixture, and fine-tuning of the ECU.
In your post you sounded like you were ripped off. I don't think that's the case at all.
#50
No, I don't feel like I'm ripped off - YET
I just feel like that those numbers don't add up...
If you say those factors are limiting the true HP performance of the SRT then explain to me why the stock numbers are high to begin with?
Remember, y2kgs mentioned that he will dyno 3 different setups on the same day...first stock, then SRT, then Weapon R. That's the fairest way to compare. And one more thing, if y2kgs has 18" wheels then why are his stock numbers HIGHER than SRT's stock GS numbers advertised on their website...
So let's see...
y2kgs got 236HP stock
SRT from their website got 226HP
y2kgs got 249HP from the SRT HFI
SRT from their website got 248.2HP...so at least the final numbers are at least consistent
Something seems fishy here though...SRT's stock was WAY underpowered assuming a very generous 20% drivetrain loss that means the stock crank HP would be 283HP???? Should I sue Lexus for 17HP false advertising since it should be 300 crank HP??
The 236HP is more like the advertised 300HP at the crank. What am I to believe??
OK, so even if the SRT GS was WAY underpowered at 226HP and on their website they got 22HP increase then I would assume y2kgs should have yielded around 258HP. Why would SRT produce lower performance numbers and yet the Weapon R produce higher numbers? If we are going by the factors you had mentioned everything should be relative since it was dynoed that same day under the SAME conditions. If it is true that the SRT did not perform well on y2kgs car, then how do you explain the wepaon R's performance?
If they are willing to offer free ECU upgrades that will improve the performance - that's great! Kudos to SRT!!! I can understand that with more tuning comes better performance and improvements...However, if they ask us to pay more for the upgrade then that really sucks since I have already paid around 600 bucks for the SRT system while the Wepaon R/ECU combo is coming in at a much lower price with alledgedly better performance.
I am just waiting for SRT's explanation before I pass any judgment but I have a feeling I already know what the response will be...
Brent
So let's see...
Brent
#51
Stock GS 236HP
SRT GS 249HP
Stock GS 236HP
SRT GS 249HP
I have this image of a big rotary **** inside the car with 'lean' on the left and 'rich' on the right.
Thanks for any answers.
Last question - when's the expected availability of this kit?
#52
Originally posted by BLiu
Hmmm....I am wondering if SRT will respond to the fact that their system only yielded 13 HP when it was advertised to have over 24HP????
Brent
Brent
Double check, they should match up.... The ONLY difference is the technique used when dynoing showed more "base-line" stock HP during the Weapon-R test.....MO posted an earlier description of why this would happen...If you do not follow the procedure listed by SRT, your dyno #'s(stock GS) will be skewed.....Brent, hope this helps you relax.....Tiny
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#53
hey, where did y2kgs post his dyno? i must have miss something
anyway,
here is the full discription for the Apexi unit
http://www.apexi-usa.com/electronics_safc.asp
just in case someone want to know.
i installed the unit on my other car before, not too hard, to install or make adjustment, just like setting a digital radio....anyway, but i have good electrical skill, look at my job description...probably not recommend just anyone to install the unit, you need to make connections for like 10wires
anyway, me want to see real dyno charts
anyway,
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#55
Originally posted by tinygs
What are you talking about?????? The ONLY difference is the technique used when dynoing showed more "base-line" stock HP during the Weapon-R test.....MO posted an earlier description of why this would happen...If you do not follow the procedure listed by SRT, your dyno #'s(stock GS) will be skewed.....Brent, hope this helps you relax.....Tiny
Could you please point me to that info where it descirbes the skewed stock HP using incorrect techniques as quoted by Mo. Thanks.
Brent
#56
First the stock GS4 is 236 plus or minus 1HP at most. I think what Brent is say is that your not getting the 28-30HP that SRT claims to give which does suck cause I spent over 600 for mine. Just remenber that in any car when you add a intake. You'll get more HP right. tuning the ECU will of course add more which is why we all are doing so.
AS for the ECU upgrade from SRT, well its not going to be free I think. Nothing in life is free so nothing bad there. Besides I would buy one that is tunable by a local shop rather than always waiting or even hoping the SRT will tune the ECU for all the mods you add weather or not if its an SRT product or not. That makes life to hard and not always the bestt way to go. One of the main reasons why Weapon R had made a ECU and not use APEXI is safey. If someone just desided to make some changes than he or she not like the outcome and at worst kill the motor. This ECU chip does come with a safey so that we will not make or do anything to really damage the car/motor.
Over all its really up to you want want you want to do but the dyno readings are right so don't even go there. As for posting the dyno sheet I will need to talk with Weapon R but don't see a problem there. Just remember like all tuner, they are not going to do or post anything unless everything is done and final. As I said before, we are going to finish up soon maybe by next week.
#57
By the way, forgot to mention that you should and could red line on 3rd for any dyno. If you can't even do that than your in the wrong business. so I don't know what SRT is talking about.
#58
What are you talking about?????? The number that y2kgs posted for SRT(249rwhp) is the exact same number on the dyno sheet shown on ths SRT web-site..
Double check, they should match up.... The ONLY difference is the technique used when dynoing showed more "base-line" stock HP during the Weapon-R test.....Tiny
Thanks Tiny for trying, but I am not relaxed yet...
Brent
#59
Brent
#60
All transmissions have the most direct path when in 1to1 mode. Less loss. It looks like they ran my dyno in 4th (the 1to1 for lexus 5speed), bc the top speed on the chart works out to about 138.
