2001 GS430 Superunleaded OR NOT???
The gas tank says use super unleaded HOWEVER if you do research many people say using regular unleaded will not damage the car.
Do any of you have any reports or websites that says you do not need to use super unleaded on 2001 GS430?
Use premium fuel. Some folks with 2001 and later GS's get check engine light by using lower octane fuel. The CEL can be reset but if the car does not burn the fuel properly, the engine could "knock" and this MAY cause a CEL. The GS is a premium car so why not treat is with premium fuel.
If you can afford to buy a Lexus, you should be able to afford that extra few bucks at the gas station.
Saving a few bucks in the long run may not be worth it if something happens to your car. My old car was an 1992 Acura legend. It called for 91 octane, but even thought it will still run on 87 octane, why not just get 91 for the insurance?
If superunleaded costs 10% more and you spend $4000 a year in gas, that's $400 extra a year for super. Over 8 years that's $3200. Not insignificant.
If super unleaded only gives better performance and does not cause any increase in services costs then I would prefer not to use super.
That's why I am trying to find out the truth about using super unleaded.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
https://www.clublexus.com/forums/sea...earchid=373836
"Premium regular fuel" as keywords.... one example thread https://www.clublexus.com/forums/sho...m+regular+fuel
https://www.clublexus.com/forums/sea...earchid=373839
"need premium gas" as keywords.... example threads
https://www.clublexus.com/forums/sho...ht=premium+gas
among many others... this is just the GS forum, other models have had the same types of discussions.
Nice calculations. You are right on. I live in California, yep it was a high of $3.25 and we drive 80 miles round trip to work.
Thanks for the links. I should have searched.
I love the GS430, the acceleration is aweseom!!!
I usually alternate fill ups (premimum one time than regular the next) on my 99 GS400. I fill up using this method when the tank reaches 1/4 full. It saves me a few bucks and doesn't seem to 'offend' the motor.
Hope this helps some!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
DaveGS4 - thanks for posting the links! There was some good information found there.
Im with the, If you can afford a Lexus you can afford the fuel. During the Hurricanes(Rita and Katrina) fuel here in Houston was as high as 3.50 a gallon if I recall correctly. I never worried, I knew it would be back down and today I filled up for 2.27 for 93 octane. During the "gas shortage" my parents put in regular and urged me too, but I told them I wouldnt do that to my car(even though I know it wouldnt kill it). My car is 10 years old(96') and runs freakin strong. Engine knock can be expensive, so be careful.
I let my younger brother borrow my GS400 sometimes, and I can tell when he puts low octane gas in it and when he uses 93. I get knock at part throttle (very faint, but I have an ear for it) and the car is just very sluggish with low octane gas. Just some input...
According to MSN, if you put a different octane other than what is designated by the on board computer, it will not burn the fuel efficiently leading to potential knocking sensor problems. Trust me, you dont want to mess with Lexus sensors, they are rediculously expensive to replace. saving a dollar at the pump is not worth it.
I filled up once with what I think was probably regular. I think the station messed up, I used the premium pump but my car was knocking on every hill on that tank of fuel so I think they put regular in the premium tank. I always use premium and usually never have knocking.
My feeling is that regular would cause some knocking even with the knock sensor trying to do its job. This is not good for your engine over a long period of time. Personally, I don't like taking chances with my $5,000+ engine.
