should i get my gs serviced at Toyota?
Old 12-17-05, 11:17 AM
Received 2,377 Likes on 1,560 Posts
I have no Lexus dealer nearby but my local Toyota dealer said they can do anything on my Lexus work except cover it under warranty (not an issue for me now).
Old 12-17-05, 07:52 PM
DREGS3
DREGS3's Avatar
Default You get what you pay for
One of the local toyota dealerships in the Augusta, GA area advertise weekly special and will provide a loaner when performing the 90k serivce. Sounds good okay, but here's what happen to me 1) bent valves due to the mechanic trying to set the timing based on how its done on the supra. I recieved all new valves curosity of this dealership. 2) oil drops in my garage caused by oil plug not tighten. 3) bent pully while put everything back together. 4) too much transmission fliud added during change. For now own I'm going to lexus.
Old 12-17-05, 10:58 PM
joshoowa
joshoowa's Avatar
well i feel that the toyota dealer should be able to do some stuff...especially for 300 owners since the 300 is the supra n/a with vvt-i
i got the toyo dealer to do a coolant power flush and it turned out pretty well
Old 12-19-05, 12:37 PM
amul
amul's Avatar
I just got my waterpump, timing and serpentine belts replaced at Schaumburg Toyota. They did excellent work. Some toyota delearships have trained lexus mechanics that can do routine maintanence.
My total cost
Water pump $168
Timing belt $28
Serpentine belt $18
Total labor $341
Total cost ~$555
BTW: the prior day, I had changed my front pads myself. The left side was really easy, but the passenger side caliper floater pins wouldnt budge( the two pins that offset as the pads wear). The mechanic had to use an impact wrench to remove that pin and repacked it.
No charge.
Know that's what I call service.
Lexus wanted $399 just for the timing belt replacement. Serpintene extra, water pump extra, waterpump labor extra. Total would have been around $700
LazyJo
CT 200h Model (2011-2017)
07-14-12 10:02 PM
GRPFAN
RX - 3rd Gen (2010-2015)
25
02-13-12 08:05 PM
drpepper
09-15-10 09:01 AM
BOWTIE 3
RX - 1st Gen (1999-2003)
04-01-07 04:42 PM
DJKLEX
Maintenance
18
04-14-05 12:45 PM
Quick Reply: should i get my gs serviced at Toyota?
