My GS Project for 2006...Advice Needed! (Longish)
Well...for 2006, I've decided to further mod my GS, but I think I'll be going a bit in the opposite direction than many GS owners. I want my GS400 less GS (Grand Sport) and more GT (Grand Touring). I've really agonized over this for the last few months, and very nearly bought an LS430. But in the end it was just too large, and frankly, not as good looking as a GS400. Bear in mind I travel many thousands of miles a year (in mostly straight lines!) and a quiet, fast, comfortable car is what I need. The LS does this in spades. And apart from my above mentioned reasons why I did not buy, another big factor is my GS is paid for. And I like my colour (Antique Bronze Mica). Don't misunderstand, I'm not trying to make my GS into an LS. I just want to slant it a bit more towards the touring side and take some of the "sport" edge off of it and give it more "smooth and quiet". Here's a pic
I've already done a few mods. They are:
18" EVO Lightening wheels with Falken ZX tires. These are amazingly strong wheels. I've hit some HUGE potholes with these and these are still straight and true. I have no doubt that if I'd been running more costly wheels, or multi-piece wheels, they'd be ruined with the abuse these have taken. I'm VERY pleased with these. The tires are also the best performance-all season tires I've ever used. And I've tried many. They are quiet, grippy, excellent in rain. They do seem to wear a bit quicker than expected though.
RMM Exhaust. Sounds great..no drone.
L-tuned shocks/struts *This will need to be changed. I'm not overly happy with these. Although the lowering looks good, the ride is harsh. Please bear in mind I don't have billiard smooth roads/highways around here. They are frost heaved, potholes, in mediocre condition. I would like as smooth as stock, or dare I say SOFTER than the stock suspension. I know I'll have body roll, but some of that will be controlled with F/R strut braces, and my Daizen bushings throughout.
Daizen bushings, complete, with sway bushings too.
Clear side lenses
LED wedge bulbs (these look very, very nice at nite.)
2800 Edge Racing Converter (not installed yet).
F/R strut tower braces (not installed yet).
Braided brake lines, Brembo OE rotors, MetalMaster pads, painted calipers.
Now here's where I need some advice...I need direction on which parts I might need, and where I might find them, or reviews from people who already own these parts. I'm also interested in any opinions that may be helpful for my mods.
I need different shocks..likely coil-overs. I need PLUSH. I hear either the HKS LS+ or the Tein CS are the only way to go. Can anyone comment on either of these? I'm not interested in air ride.
Sound proofing/deadening. I'm really clueless about this, and would like opinions from anyone who has done this, or could offer advice on how best to do this. This isn't for stereo reasons (my girlfriend is deaf, and I'm not an audiophile) this is for quieting the cabin a bit.
I will be doing some type of blackwood interior trim or either refinishing my stock pieces if they are in fact real wood (my dad is a master wood worker)
I'm looking for a LSD...I need it to go with my TC.
Am I missing anything? My immediate mods will be with sorting out the suspension and making the cabin a more pleasant place to be. What say you, fellow GS owners??
Clear side lenses
Alright, here is my advice..........
Suspension.......... go with the Tein CS with EDFC......the CS are as comfy as your going to get in a coilover, you will be able to adjust the drop (which you cant do now), and with the EDFC you can adjust the dampening for the times that you want to stiffen it up a bit for spirited driving.
****by the way, I would bet that your ride is a bit more harsh now due to the Daizen bushings
Sound proofing.........I bought my GS from a guy that owns his own high end car audio manufacturing company. This car was sound proofed well beyond the norm.....but it was quite. Take out the interior, as much ofit as you feel comfortable doing...its actually quite easy. Install Dynamat or similar on the floor boards, doors, trunk, etc. The guy I bought my car did this, and he added a foam padding under the carpet, behind the rear seat, behind the trunk panels, etc.....this thing was quite. The padding was like carpet padding, nothing fancy. I took most of that out for weight reasons with my current set up.
Blackwood.........the wood trim is not real wood, but there area few places out there that can re finish the factory wood with a blackwood finish using the saem basic process the factory does. PM me if your interested in their info.
LSD........just keep your eye out for a used Supra TT auto diffrential with LSD, this works out perfect and swaps right in. IF you buy from RMM, that is what you are getting, a factory part. You can also buy a TRD LSD and have it installed in your stock diff, but the Supra TT diff. will give you lower gearing.........quicker off the line. I had the torque converter with 2800 stall and the Supra LSD on my old GS, it was quick......best bang for the buck.
Good Luck............
Thanks for the prompt reply! I just wanted to let you know I could tell virtually no difference between the OE bushing and the Daizen.
As for the Tein CS, I notice that the HKS has softer spring rates with their kit. Have you tried both of those, or is your experience with the Tein only? Thanks!!
Actually the HKS LS+ have higher spring rates. It is stiffer than the teins although I've never had it at the softest setting.
HKS stats:
LEXUS GS300 1998-2004 front: 10 rear: 9
Tein stats:
LEXUS GS300/400/430CS front: 9 rear: 8
HKS stats:
Tein stats:
Really? Manaray had compiled a list that showed the LS+ at 7/5 The numbers he provided for Tein CS are the same as the ones you provided...I know the numbers you provided are the numbers from their website...wonder if they've changed since Manaray compiled his list??
Keep in mind that a lot of the ride feel comes from how the shocks are valved. The spring rates will matter but not as much as the shocks. Obviously, they work together but in different individual ways.
Look at the Tein Flex and CS. The spring rates for the Flex are 10/9 while the CS is 9/8. They are only one step away. The shocks, however, are different and if you ask anyone who has ridden or owned both, the ride quality is VERY different.
Hey if you wouldn't mind putting it on the softest settings for either Tein or HKS, I'd sure like to hear how spongy it is..or how much softer compared to stock. I suspect even if it is softer than stock, it will still handle better than stock GS shocks...
Well I have to say that it rides very nice at the softest setting. A hair stiffer than stock but hard to notice. It feels very similar to the Tein CS. It was a bit wet here so I didn't do any agressive driving. It does still handle better than stock, its pushes a little more than when I have it set stiffer but thats all expected. Either choice would probably be good, if you want the EDFC function Tein's is the only way to go. But as far as adjustability the HKS wins hands down.
Can you elaborate on that? I'm not sure what you mean? Is it difficult to adjust the Tein without EDFC, or is there something else? Thanks again...I'm learning plenty!
if you want to make the cabin quiet or reduce the road noise. i wouldn't invest in Dynamat I tryed it and it gets the job done but there is better, when I had my accord I had a system and in order to reduce the rattles and road noise I bought sound deadner from secondskinaudio.com. i bought their liquid sound deadner and sprayed the whole trunk and it made a huge difference. I also used their rattle pad and damplifer. Check them out they are cheaper than dynamat, it also weighs less and a lot better quality.
