Good news pi torque converter is awesome!!!
I just recently had the pi tc put on my 03 GS430, and over the holiday travel, i put about alittle over 1K mlles on it. Yes no check lights or anything, just pulls hard through every gears, and plus burnouts are a cinch even wiyh 20X10" rear wheels. HAHAHA i'm so happy. just wanted to share with my Bos on CL.
Originally Posted by nate579
Great news, did you have to install a transmission cooler? On normal acceleration is there a difference in acceleration from stock? Gas Milage? I am seriously considering doing that install.
EV ftw!!!
Your whole attitude to driving needs a major re-adjustment. The car wants to do burnouts now all the time. In a good way - meaning it is easy to learn how to control the new found aggression in acceleration.
IT IS THE BEST BANG FOR THE PERFORMANCE BUCK - PERIOD!
Couple that with the 3.76 LSD rear diff, and your car becomes completely and totally different animal.
Originally Posted by e-man
Just curious. Can you do one without the other?
edit: Just read your profile and its says you have a gs400. From what I understand, you should have no problem with the cel if u get a tc
Originally Posted by rheiy
Yes, you can do either. I have the 3.76 lsd but not the TC. With the 3.76 you also get a good jump off the line and the car will pull stronger in all gears. I've thought about the TC, but I just can't risk getting the cel since my state uses odbII to check emmissions.
And what about the other way around -- TC without the LSD?
Turn vsc off and u can burn lots of rubber. But if you burn too much rubber you lose time getting off the line. Either one is a great mod but it's always better to have lsd if you get a TC
You can go that way as well but with a tc and no lsd, you will have some traction issues.
Seriously considering doing this mod??? It's a no brainer. The difference between the stock TQ and this one is like the difference between night and day. Yes, it is that different.
No brainer to you, but some of us don't have $5,000 to replace burned out transmissions. And the need to gain .5 sec on a 1/4 run is not on the top of my list.
