NITROUS QUESTIONS!? attn:kodai
kodai or anyone using nos on a GS400
What all did your system include? Any form of computer ECU upgrade or just a run of the mill "wet" kit? Where did you tap into your fuel system? Is there a port on one of the rails or did you T into the fuel feedline?
Do you use a RPM switch to turn the nitrous on and off? What size shot are you running?
Thanks in advance,
James
Thanks in advance,
James
There is always the chance of blowing up your motor each and every time you spray...I ran a 150-200 shot on my C5 vette for a long time, but one day I accidentall hit the rev limiter...= fuel cut....boom! Any time you use it, always be aware of the consequences and NEVER GET GREEDY! I would suggest a 75 shot...see Mean Gene for more details....hope this helps
If I had a lease...I would consider spraying this car, but I am in it for the long haul...
no N20 = less wear and tear
There are ways around the rev-limiter problem you had. These motors are so over built it is crazy, I can only imagine the amount of n20 one of these things could hold.
6-bolt main,
steel crank,
forged pistons,
forged rods,
i mean come on, this sounds like a race engine..
6-bolt main,
steel crank,
forged pistons,
forged rods,
