Well i got some aftermarket pedal covers for christmas and was wondering if you install them over the stock rubber or do you take off the rubber... Thanks
well here they are... The gas pedal has this plate that goes in the back along with a few screws etc.. I assume the plate will slide over the exsisting pedal...
I have the exact same design ...but are those RAZO... mine are ...
yeah take of the cover for a better fit ...the accelerator will fit fine but the brake might fit really close to accelerator (but maybe because I bought the big set ) in the begining you might hit both pedals at once
one more thing is I put some double sided tape on the breake pedal due to that with use the pedal cover might start to move.... which it did on me many times ...so the double sided tape helped w/ that and no more problem
Thanks Lexism..... The brake pedal fits fine...I didn't have to take off the rubber. and they don't touch.. Now the Gas pedal is on there but sort of loose... I used the strap they gave me and it works but the bottom of the pedal is loose.. The kit came with two pieces of double sided thick tape that i will use on the bottom. I think that will slove the issue.... The pedal look great...
