Wind Noise 99 GS300
I have enjoyed "lurking in the shadows" here on the CL forum for several months now learning as much as I can.
Although I am enjoying my car I do have one thing that is really annoying. When I roll my drivers side window down and then roll it back up I get this bad wind noise coming through the upper left hand side of the drivers window. I can roll the window down slightly to get rid of the noise.... but I'd like to get it fixed.
Anybody have any ideas?
BTW, I did a search and found a couple things but not quite what i was looking for.
I have that same problem... it happens on the highway when i roll up my window i have that wind noise and when i just give it a touch downward the wind noise stops... Ive just learned to live with it for now cause im too busy to trouble shoot it.
Just a thought. You might also want to check the undercarriage plugs. Do a search and you'll see what I'm talking about. Basically, if the plugs fall out, the wind enters from the underside of the car and travels up through the a-pillars and sounds like it's coming from the window when it's really not.
Thanks for the quick responses. I did check the plugs before when I was doing some research and found that some were missing. I will get them replaced and check the weatherstripping.
Thanks again for the help!
Lysmau
04-23-15 08:21 PM
