Not quite getting the shifting thing?
As most of you know by now I recently bought a gs400. I read the manual about how to shift and I went out and tried it for the first time.(because I usually drive in "D"). The shifts don't seem to make a difference to driving in D to me, but I'm pretty sure that I am doing it wrong! Any suggestions from my CL elders ?
On the steering wheel there are up down buttons that I'm not totally understanding what to do with, that's basically the situation I'm having! When do you use them, and how?
Stop, put it in M, paddle down to 2 and then stomp on it, paddle into 3rd at 6000rpms etc etc
jonny
Originally Posted by Dx3
Well, you get to choose where you shift into the next gear - so yes.
Jonny
Jonny
THEN you'll be driving it like you stole it!
Forum Administrator
Couple of things to do
1) if you don't have an owners manual, get one and read it. You can get it free from Lexus, here's how
https://www.clublexus.com/forums/great-deals/92845-free-lexus-owner-s-manual-if-you-lost-yours-interesting.html
2) try searching this forum to see how other members use e-shift.
use 'advanced search' to point at the GS forum and search for keywords like 'eshift' or 'e-shift' or 'e-shift faster'
3) General consensus (and my opinion as well) is that in a sprint the car is faster letting it shift auto, with pwr 'on' on 'vsc off'. I use e-shift to slow down or to be in the right gear when I want to get a jump.
Originally Posted by TheSupe87
LOL - nicola you must be over 30. No offense, I just got a kick out of your comment. I'm with you, Nicola, I'm only 23 - but I still like to have fun once in a while. On my supra I have a similar feature - but instead of being able to control the shifts, I just have an ECT button - when I press it, it will shift at like 6000+ rpm (no rev limiter) in ever gear, depending on how far you've got the pedal pressed
I'm actually 21 . I was just commenting on the guys lack of understanding when it came to shifting an auto - he just seemed to lack a lot of the common sense that keeps most of us from buying a new tranny... I've driven stick since since I had a license and I miss it a lot in my GS4, and the buttons on the steering wheel are a joke. I usually manually shift with the shifter if at all (allows you to keep it in 1st anyway).
Can you press either button (left or right) to shift, or do you have to press both at the same time?
Also, say you are in D and you're at 40mph in 5th gear. If you romp the throttle, the tranny will kick down to whatever gear is optimal for the situation. But wat happens if you're in Manual mode? Does the tranny stay in the gear you want or does it kick down also?
You can press either button. It will down shift to a lower gear.
5 on the shifter does the same thing as 5 in manual
There is no 4 on the shifter it is only available in manual
3 on the shifter does the same thing as 3 in manual
2 on the shifter does the same thing as 2 in manual
1 is available on the shifter and not in manual mode
