Yellow Fogs - Film or Lense
I just upgraded to 6000k HIDs and now I'd like to get the yellow fogs to enhance the look. I looked into buying the OEM fog assembly which would be the practical approach, but I could get out a lot cheaper either buying yellow film for the inside or buying 3000k look-alike bulbs.
My question I had though is if there IS a yellow film inside the foglight, is it directly infront of the bulb shield, or on the sides? Does anyone have a picture of the inside?? I doubt it, but If I do take the film approach, which would look better from the exterior or the car, I want to do it right.
On the stock foglight I believe that the reflector inside is yellow. Personally I think the stock yellow fogs look alot better than fogs with yellow film covering them. When the stock fogs are turned off the look clear with only a bit of yellow coming through the lens.
exclusive matchup
Originally Posted by j stuff
When i took out my fogs inside the lense inside is yellow. It IS the bulb shield. I have the yellow fogs but i am also getting the yellow overlays from aerotect here on the forum. Ill post pix of it hopefully 2morrow when it comes in
I just had the yellow film I got from Aerotect put on my 3GS and I love the look:
More pics on my thread: https://www.clublexus.com/forums/sho...d.php?t=200349
How easy is the film to apply and remove. Is it sticky on one side or did you have to use a heat gun? I want to know if its easy to remove incase I decide to buy the actual housings. Oh and how exactly do they stand up to water
Thanks guys.. I'll probably get that film pretty soon. This doesn't really have anything to do with the topic, but I decided since I've got peoples attention I'd ask another question.
I usually listen to rock but today I put on some music with pretty heavy bass and it sounded horrible. I looked in the trunk, under the rear deck and saw that the sub has been removed and all that's hanging in its spot is the level line converter. I figure I'll have to put an aftermarket sub in and it'll give me a chance to upgrade anyways. Do you guys know what size the OEM system sub is? It looks like maybe a ten, but I wonder how hard it would be to get it cut out to fit a 12....
