Look what showed up today at my door
Alright, alright. You guys must really be stumped (or, more likely, just don't care because it says Toyota on the box
Here's the final hint. If this doesn't help, I don't know what will:
And another (I still can't figure out why these need to be replaced -- they're a solid piece of metal):
Originally Posted by GSquicksilver
that's what i've been trying to explain to you. i can't see a reason why these need to be replaced since it's a solid piece of metal. i can only see replacing these if a bolt stripped off. if these are tighted down to the frame, how can they make any noise? unless they weren't tightened down all the way and it was hitting the frame from bumps.
Hey, Eric where are strut top rubber pieces? I tought they come with rubber which i tought is part of strut top,
I tought it is a set strut mount and rubber, if you can get brand new rubber at local dealer, send those back, s***
It's more about rubber piece than metal part, since they sell it alone, send it back man
There is rubber piece betwen spring and strut top, you must use new rubber..
I tought they sell strut top and rubber as set, looks like they are not, so find out if you can get rubber piece
Originally Posted by daltexlex
if you were paying to replace those struts with original equipment, you may as well bought L-tuned ????
Originally Posted by chuckb
allow me e
- it's factory or nothing for e. plain and simple.
