steering wheel vibration
Well I had my car taken to NTB and they rebalanced my tires and torqued them to correct specs but my steering wheel is still vibrating (not as bad as before). What could it be?
I was reading a post where you recently purchased new rims. Nice rims btw For the rims, what was the hub size? Usually buying aftermarket wheels, they make the hubsize universal, so you might need a hubcentric ring to make it fit to the stock hubsize. Without the hub rings the steering wheel might vibrate from the rims/tires/ wheels.
Also, at what speeds is your steering wheel vibrating? 20 30 40 65+ mph? or when you are braking?
more info
more info
another possibility is worn lower ball joints or lower caster arm bushings. I changed out my lower ball joints and it removed some vibration, others have installed the bushing kit from daizen and reported excellent results.
folks
do the daizen bushing upgrade , if not all due to finances due the castor arm , it accounts for 90% of shimmy and vibrations .. it works , daizen did it right , i am surprised that everyone here has not at least done the castor arm bushings , if you remove this arm and look at what toyota put there you would clearly understand
the bushing kit is only 100
i did mine months ago , i dont drive my car everyday anymore , some times for days it sits and we all know the flatspotting issues , i dont have any even after sitting for days, i dont have the dreaded tire warm up scnerio its just smooth all the time
Well I know when I was riding on my stock 16s everything was fine (smoothest car I ever drove) so I dont think its the bushings, but where can I get those hub rings and are they expensive? And it usually starts vibrating aroung 55-60 mph everything rides smooth before that, and there is no vibrating what so ever when I brake. It bothers me so much I might take off the rims and go back with my stock rims
I bought some from EBAY.
I didnt buy it from this guy, but i think these are the same.
http://cgi.ebay.com/ebaymotors/HUBCE...QQcmdZViewItem
good luck bro
oh btw: CHECK THE BOX OF THE RIMS YOU BOUGHT!! They should state the HUB SIZE!
good luck bro
Ktang....Don't tell me you are going back to stock because of a little shimmy....you can resolve that...I had a similar issue after getting my Milanos bolted on...They forgot to put hubcentric rings on each of the four hubs....This may be a long shot but since your wheels and the ones I got are similar builds...I would say you will need a set of 73mm hubcentric rings..which is what I used and they fit perfectly..
I had the exact same problem. Rode perfect with the stock 16's and then I put some aftermarket wheels on (with the hubcentric rings) and had a shimmy between 55-75 mph. It cost me $60 to have all 4 wheels spin balanced while mounted on the car and problem solved. You will be surprised at how hard it is to find a place that does this work......very few.
