How much does OEM 17" 01-06 GS Wheel Weigh?
I tried searching the forums but couldn't find the answer to this question:
How much does OEM 17" 01-06 GS Wheel Weigh without the tire?
I am thinking of upgrading and want to compare different OEM and aftermarket options.
Thanks in advance.
Thanks in advance.
without the tire, the stock GS 17 weighs in at 25 lbs.
here is a thread where they compare the weight of the stock LS rim to the stock GS 17. RominL states that the stock GS 17 weighs 25 lbs.
https://www.clublexus.com/forums/sho...ock+rim+weight
yikes! i had no idea it was that heavy! no wonder why some people say they didn't gain any weight when they went to a larger aftermarket wheel...
i still remember way back when i used to own an integra type-r... i had spoon sw388's on it and i think the wheel weight was ~12lbs?
I just weighed a stock GS 17 rim on the scale tonight (no tire and no center cap). It weighed 23 pounds (my scale only weighs in increments of 1/2 pounds, but it's pretty accurate). So, technically, the rim could have weighed anywhere between say 22.75 and 23.25 pounds.
reading was 50lbs. Subtracting 26lbs for the tire (per weight in tire rack specs) gives a wheel weight of 24lbs. Of course this was a bathroom scale and we all know that each scale can varry a bit. So I guess it's safe to say the oem rims weigh somewhere in the 23 to 25 lb range. Now if someone can get access to a doctor's scale, we'll know for sure.
Kajukenbo
Wheels, Tires & Brakes Forum
12-31-01 05:19 AM
