Should I be worried about the GS4 problems?
Hey all,
I'm going to be getting a car withing the next few months, and its between an IS300, GS300 and GS400. Since I probably don't want to spend more than 17-18,000... it'll probably be a 98 or 99 GS400. I've searched and read all the threads on the common problems. I'm not too concerned with headlight condensation or rattles or such. What does concern me is the low idle and starter problems. Since I won't be buying a car under warranty... and i'm going to be a first year medical student.... I won't have the money or the time to take my car in to the dealer several times as they attempt to fix a problem. It seems that some of you who've had the low idle problem have been able to get it fixed, but I'm under the impression that dealers have not been able to fix the problem for many of you after repeated trips and replaced parts. In your objective opinions, do you all think the low idle problem is something that happens to a good portion of the 1UZ GS's (like half or more?). Its ok if I just have to replace something once I guess, I just don't want the nightmare of the dealer trying over and over again, charging me money, and still not being able to fully resolve a problem. What are your opinions on this?
Also, how common is the starter problem? I read about it from time to time and it seems extremely expensive to fix, but is this a less common problem with the GS4's? Thanks everyone.
-Faraaz
PS- I'm going to be moving to Ft. Lauderdale, FL for med school... how are the dealers in the area?
-Faraaz
Congrats on going to med school
Ive heard alot of about the low idle problem, even felt it one day when my windows were down and the a/c was off and I was sitting at a red light. But after reading the post about keeping your a/c on, Ive never had that problem again.
Ive had starting issues, but like some on here, it was attributed to the terminal connections being loose and dirty. Once I cleaned the battery terminals, and tightened the connections, everything was fine.
Good luck with which ever vehicle you purchase...and with med school too
personally
things will wear out, and I think A new starter during a span of 5-6 years isn't bad. The low idle isn't a issue in my opinion. Good luck with your future in med school.
My GS400 is a 98 with 85k and have not experienced either of those problems yet. It starts and runs perfect everyday even when its 5 degrees in MI. Get a GS400, if you get a IS or GS300 you'll be dissapointed you didn't get the V8!!
^^^the starter on my 95 ES lasted until about 90k miles, then the contacts had to be replaced.
too bad you can't get to the starter on the GS as easy as it is on an ES.
Originally Posted by e-man
This is the one problem that really scares me because once the starter goes out, you must get it fixed and it's silly expensive to do so. You do read about it from time to time, but remember, only those people who have starter problems are talking about it. You don't see threads entitled "Just turned 100,000 miles and still have the original starter." That being said, I think it would be really interesting to start a thread devoted solely to this topic -- what year is your car, how many miles to you have on it, do you still have the original starter, and, if not, at what mileage/year of ownership did you replace it.
hehe i just had to replace my starter at 102K!! ended up costing $700 (under warranty!)...and get the GS4....you wont regret the v-8....low idle is not really an issue unless you're planning on putting on an exhaust...good luck!
Hey all,
-Faraaz
-Faraaz
I have had my 98 GS400 for 2 years and I just replaced my starter. I got it with 47K on it and it now has 70K. I have an amazing mechanic who was a friend of a friend. Now he is a friend of mine. Honest and a Toyota freak. I just brought him my gradmothers 94 ES300 to see if I should buy it from her, she is too old to drive and he told me after looking at it for 20 minutes, don't even let her sell it to anyone you know; no charge. He is the best. My starter along with a lot of other maintenance things was $800. No other issues. He is in Delray Beach which is 20 minutes north of Ft Lauderdale. Private Message me for his info. You will love the car.
the most common problems I've heard/seen on the 98 are:
hood latch cable getting stuck and so it won't close
door lock actuators failing
starter going bad / plunger getting stuck
radio display going whack
I came from a Dodge Neon, where it's top 4 list of problems are oil leaks, blown head gasksets, seals, paint fading and rust.. so, it's comparatively nothing to speak of. No car is going to be perfect , I just expect the important stuff (engine) to work. I got my 98 GS4 121k miles off ebay for $11.5k back in Sep 05 .. and the leather and torque still wows me every time. My only gripe is the gas mileage, but it would have to get to $4 a gallon before I'd consider selling.
Originally Posted by 17gs400
i got rattle problems
I suggest you should save your money , buy yourself a 4cyl accord or camry until you get out of school. If those cars break down, first they rarely break down, they would be relately cheap to fix.
If you got 17-18K to spend, why not buy a new car with warranty if you are worried about common problems with the 300/400. When you get out of med school, residence, and start making big $$$, then buy yourself something nice.
You are asking a rhetorical question about spending money to fix a car which you do not even own . At this time you can afford to spend 17-18K, but fixing the same problem over and over again would be too costly for a med student. Why not avoid it all together by buying new w/ warranty
You definately won't have enough time to pimp while in school. Believe me I know.
Good luck in your decision.
The engine is one of the least likely parts of a car to fail... manufacturers have mastered it. The tranny is actualy much more complicated and more likely to fail...
Any reason why you wouldnt rather have a 98 SC400 instead? i can tell you id love one.
