Differential leak due to leaking input shaft seal???
Originally Posted by DASHOCKER
Diffs rarely fail.
I know it's rare, but even Lexus cars can have weird probs.
Originally Posted by chuckb
did I mention that my entire diff and one halfshaft was replaced under warranty at 23K miles?
Wow.. Well I have 96k so far and no diff problems thank GOD.. Well I have all synthetics, just a little insurance from wear and tear. Tranny, engine, differential power steering all with the liquid gold inside
I took the tech for a ride and he heard it, put the car on lift and came back in 3 minutes and said I was getting a new rear end and axle. That tech has been the only guy I let touch my car since.
now I wish I would have begged them to order a supra diff instead, I doubt they would've though.
this is just a suggestion... http:www.auto-rx.com
we unfortunate rx300 owners with oil sludge problems use this stuff and it works. it is also used for transmission and differential leaks as well. it might be of consideration to you?
Originally Posted by saelee39
how do i know if i diff oil is low?
The differential has a fill plug on the cover that faces the rear of the car. On all cars I have ever worked on, you add oil until it reaches the fill hole level and just starts to overflow. Then you put the plug back on.
VT
Originally Posted by pianovt
6. Remove the sleeve/spacer. This sleeve is not reusable. It was deformed intentionally when the factory people tightened the nut that holds the drive shaft flange in space.
I'm about to order this pinion seal 'cause clearly my diff is leaking from the main seal area.
https://www.rockauto.com/en/moreinfo...377&cc=1373846
Do I need the spacer/sleeve also and if so, what part do I order?
https://www.lexussouthatlantaparts.c...031144005.html
Take a look at the diagram. All of the parts for the diff are listed if you need anything else
For 1999 Lexus GS400 (in California), what's the best conventional (non-synthetic) differential gear oil to use ?
1999 Lexus GS400 Owner's Manual says...
Hypoid gear oil API GL–5
Above –18_C (0_F): SAE 90
Below –18_C (0_F): SAE 80W or SAE 80W–90
- Lucas LUC10043 Oil SAE 80W-90 Heavy Duty Gear Oil - 1 Quart
- Castrol Axle Limited Slip Gear Oil - 80W-90 - 1 Liter 12612
- Other ?
- Other ?
90311-44005 and 41231-50010?
Edit:
- Other ?
- Other ?
2007 is250
I have a 2007 IS250....Shop just told me they have to remove the axle in order to re-seal the differential and stop a leak. $1800. I find this hard to believe...Any ideas?
