Differential leak due to leaking input shaft seal???
I had lexus checked out a leak and they told me that it was the differential due to leaking input shaft seal. est. $700.... i was wondering what has to come off to get to this seal? is this a difficult job? please help..... thanks
Originally Posted by DASHOCKER
Get a new dif.
http://www.trademotion.com/partlocat...=2&catalogid=1
If it is I would tke my pic to a few places that work on transaxles like an off road and 4x4 place they do alot drive line work. just becuase it on a Lexus does not mean they can not remove and replace a differential.
you can see if it is the pinion seal i5 is only $13.
Originally Posted by chuckb
there must be a cheaper/easier way than that.......if the dealer said $700 to fix, it can probably be done for about half that much $$$.
Originally Posted by Benjamin T
i see where his comment is coming from... a used supra lsd diff is almost $900-1000. so if it does turn out that this seal is a $700 job you might want to think about this.
big pics
I have done this job a few times, but not on a Lexus. (The design is just about the same on all rear wheel drive cars.) The input shaft seal is the one facing the transmission, and it's a little trickier to replace than the other two that face the wheels. Basically, you have to do the following:
1. Mark the exact position of the driveshaft center bearing relative to the body. You want the shaft to go back in exactly in the same position as it was when it came from the factory. If the driveshaft comes apart, make sure you either don't separate the halves, or mark them so they go back together the same way as they were. The shaft is usually balanced with a weight, just like your wheels.
2. Remove the driveshaft, either entirely, or just swing the differential end out of the way so you can get to the flange on the differential. On many cars, you have to clear out other stuff like the exhaust in order to do that.
3. There is a tool to hold the flange while you unscrew the big nut in the center of the flange.
4. Pull off the flange.
5. Pull out the defective seal.
6. Remove the sleeve/spacer. This sleeve is not reusable. It was deformed intentionally when the factory people tightened the nut that holds the drive shaft flange in space.
7. Install new sleeve.
8. Install new seal.
9. Install Flange.
10. Tighten the flange nut to specified torque. The new sleeve will be compressed and deformed. After you have done this, do not remove the nut, or you will have to start with a new sleeve and seal.
11. Reconnect the rest.
The question is, why did the seal fail? Does the differential make any noise when you coast or back off slightly from the gas pedal?
You can do either of the two things: have it repaired, or get a used one from a salvage yard. I would not offer more than $250 for a used one. Differentials rarely fail, and salvage yards probably see no demand for them. Swapping out the differentials may however cost you a few hundred dollars, depending on who does it.
I doubt that the Lexus dealers have any more experience with replacing the seal than someone who works on transmissions and differentials.
Also, how big is the leak? If it's just a little damp around the bearing, you could ignore it. If it's dripping, that's another story. As long as you keep enough oil in the differential, nothing bad will happen to it. Try wiping off the leak and drive for a week or a month to see how serious it is.
VT
Originally Posted by pianovt
Saelee39,
9. Install Flange.
VT
9. Install Flange.
VT
Pretty good info tho.... for you buddy
Get a new dif.
when you say get a new diff oil, does that mean replacing the whole oil with something different? what types are there? .............i am not really familiar wit this....the dealer wanted 700 for labor + seal, i dont know if this includes replacings it with new oil....
I doubt replacing a seal costs $700 anywhere else besides the dealer though. It looks simple, only one page in the svc manual....
Saelee39,
9. Install Flange.
VT
9. Install Flange.
VT
i thought we were talking about the main input shaft (ie. driveshaft), not the output side shafls/axles?
thanks dash,
