Power Outlet Problem
Well, I managed to burn my power outlet up using a small compressor to fill up my tires. I pulled it out and it looks like this:
I tried another outlet from my friend's GS and it worked fine, so I didnt burn any wiring. Could I just solder that small wire back together or put another wire in there without risk of burning something else up? Almost scared to ask how much the Stealership wants for this outlet.
Originally Posted by Tranman
wow...wonder why the fuse didn't pop...
Registered User
Originally Posted by Ultraspeed
yeah i wondered the same thing. compressor just cut off in the middle of pumping the tires, i switched to the lighter and it worked fine.
anyways, yeah, you should be fine reconnecting the wire...just make sure there isn't any bare wire....
I believe that is a "fusable link". They blow before the fuse. Not the smartest thing, but pretty common on power outlets. If you just resolder it, there will be less protection than what the factory link gave you. Bypassing it really is'nt an issue, you'll probably blow fuses first, which isn't a big deal.
Originally Posted by recco1
Where is the fuse located???????
i took the burnt wire out, added a small piece of new wire and soldered it in place. seems to work fine now with a cell charger.
for future reference, i found another thread where a member did the same thing when he used a compressor on his outlet, apparently not good.
Seems like the outlet in the armrest was meant to take less load than the one in the ashtray. I'd recommend not plugging in anything more than a cell phone / pda charger into the armrest 12v outlet.
IneednSC
SC- 1st Gen (1992-2000)
02-19-14 02:01 PM
