hit a roadblock....brain is fried
the car is getting put back together finally ..
the HID's wont turn off after I shut the car off...put in a new optima battery in today and hit the lock button twice,but the lights stayed on...any help...I'm getting back into the working on the car again since the weather is warming up a little out here...
I 'm hoping it something easy...I have to get back into the swing of things...btw the fogs are not mounted ..not sure if this relative
thanks guys....
johnny
oh btw the new rims came in today...waiting for customs
thanks guys....
johnny
can't wait to see the new rims. But onto the lights. So even after you turn off the switch for the headlights, they stay on? seems like a short somewhere. when I installed my OEM HID's I didn't have them installed on the car either , and don't remember this happening.
When was the last time the lights worked right?
thanks for the reply..
God...last time the lights worked...????? Maybe around sept-oct of 2005
I cant be sure...for some reason I dont think it's a short ...but maybe
3UZ-FEEEE
Did you check the relays, and wires going into the lighting stalk? If you've ever tried to mod you're lights... like the fog light mod on Banana GS's website, the wires sometimes get loose, and constantly harassed by the motorized steering column (that’s what happened to me.)
I can relate Johnny... last time I went to the body shop, I started the car and EVERY idiot light on the dash was lit up (except for the oil light, which went off quickly... thankfully). I guess if you remove all the lights, glass, door panels, etc. from a car it sort of ... freaks out.
Check the fusible links and fuse box. Hopefully nothing is fried!
Can't wait so see your masterpiece!
Originally Posted by Stage3
I know this sounds stupid, but check the trunk and the gas doors. If they are closed, pop them and close them again. I noticed that when the trunk is popped the lights will not turn off at all. It's silly, but sometimes it's the little things...
little searching here and there....i think it might be a relay ...when i pulled the relay out, the lights when off ...possible stuck relay
thoughts ??
thoughts ??
thoughts ??
thoughts ??
Good Luck J
Jonny
I had that happened and must've pushed the remote a million times before realizing I didn't close the trunk
I didn't know about the gas cap?
