Leaking Power Steering - Please Advise
Hi guys, I had some work done today on my 99 GS400 and the tech said that my car is leaking power steering and therefore the power steering pump should be replaced.
My question is - is this a common problem on GS4 and is it fixed only by replacing the pump (the pump itself is around $400) or there could be a problem with something other then the pump.
Thanks in advance.
Thanks in advance.
leak
Two questions:
1. How is Lucas gonna help when there is a leak?
2. The color of the fluid that I always add is clear and the fluid is leaking. So where most likely is leaking from and what should be done to fix it.
Thanks
Thanks
Originally Posted by DASHOCKER
The most neglected fluid on these cars is the powersteering fluid. It should be cherry red in color. If it is not, it is time to change it or else there will be more threads like this. Good luck with the fix
cherry red?
Originally Posted by myLexRX
Two questions:
Thanks
Thanks
