1999 GS300 - OEM halogens to 2004 Green-tint OEM Xenons...any errors?
I currently have a 1999 Blk GS300, and I have the OEM halogens. However, I just bought a set of OEM xenons out of a 2004 GS430. These have the pretty green-tint on them. My questions are, one, is it as simple as splicing wires (+ and -) to make them work, and two, will it trigger any errors that could annoy me everytime I start my car up? Please let me know...local mechanics here tell me it can't be done, but I know it can...I have been reading around, and I know a simple headlight assembly switch is doable. We're not trying to move the Earth!
So you've seen the conversion, but have not done it yourself? Anyone out there done it can elaborate? I really want to do the conversion, but a bit apprehensive about the splicing. Help a fellow Lexus owner out. Thanks in advance!
My 99GS3 (just like you ) didn't have hid.
I bought the whole hid headlamp (with ballast, bulb, auto level motor) and swapped out the halogen headlamp.
It's not plug and play obviously. Just splice the wires and you're good to go.
The motor won't work so don't bother with it.
Halogen had the regular 9006 socket.
Oem hid had smaller connectors. I cut the connectors (only 2 wires) and cut the 9006 socket (2 wires) from the vehicle. Checked the polarity on the car with a tester and just wired/solder them together.
I was hesitant because I wondering if I should add a relay to it. It's been working since 2000 and no problems
I've been wanting to upgrade to the green tint also.
Let me know if you need help.
And no error code.
Hey, I just brought a ballast and 2 D2S bulbs, split the wires and plugged em in on my 2000 GS300. Only problem is the housing I think isnt big enough, so 1) the new bulbs dont go all the way in 2) the lights arent focused. You cant really tell, but I know they aint. Would this not happen if I just brought new housings from a GS400?
Originally Posted by wilassasin
Question will the HID bulb etc..from a new ES work with a 98-05 GS300-400?? anybody ..
D2R= Reflector housing
D2S= Projector housing
If you guys have any other questions feel free to ask. I've had plenty of experience with HID's
About to install my 6 HID bulb setup soon
Good luck to both of you,
Jeff
