JZS160 Or JZS161?
JZS160 Or JZS161?
Guys, I own a 1998 Lexus GS 300. I am about to order some aerodynamic parts for the car.
I need the accurate anwser from experts! Is my model a JZS160 Or JZS161??
I'm so confused !!
Thanks
I'm so confused !!
Thanks
Well, 160/161 is the same car. In Japan there is a twin turbo GS rather than the V8 GS400/430 found here. Either way getting 160/161 body parts do not matter, but to be on the safe side...the GS300 is a JZS160. Toyota Aristo V300 TT (Aristo= GS in Japan) = JZS161
I think all parts are interchangable besides the LED mirrors. This is due to the Japanese cars being right hand drive.
[QUOTE=JeffTsai]Well, 160/161 is the same car. In Japan there is a twin turbo GS rather than the V8 GS400/430 found here. Either way getting 160/161 body parts do not matter, but to be on the safe side...the GS300 is a JZS160. Toyota Aristo V300 TT (Aristo= GS in Japan) = JZS161
Thank you for the prompt response Jeff. That explains everything I thought JZS160 was refering to the 1st Gen GS300.
I needed to confirm the info to purchase a TTE Front Lip. Thanks again
I'm so confused !!
Thanks
I'm so confused !!
Thanks
It should read JZS160L-BEAQFA. JZS= Chassis Code (usually coded w/engine block series i.e 2JZ) 160 = Generation designation. The L designates = Left Hand Drive. For the RHD, there is nothing listed after the chassis code.
Here is what it looks like for any Lexus before 2004:
Here is what the label looks like 2004 and after:
JZ160 = 1998 to 2000 GS 300
JZ161 = 2001 to 2005 GS 300
as far as ordering kit for your car.. It shouldnt matter because the only difference is the tail lights and e shift. Body,Chassis,Suspension components are the same.
Hope it helps
Tommy
Hope it helps
Tommy
Hope it helps
Tommy
Hope it helps
Tommy
JZS160=ALL 2nd gen 98-05 Lexus GS300 and Toyota Aristo S300
JZS161=ALL 2nd gen 98-05 Toyota Aristo V300 TT (This is the only car with the JZS161 designation)
UZS160=98-00 GS400
UZS161=01-05 GS430
Body parts will be identical for all 4 types listed. Basically the same car, just different engine.
Rfierro223 (10-16-22)
