Rod Millen STB?????
Originally Posted by blacksc400
It has a very good clearance...
I have it on my GS4 and it clears even my EDFC!!
You shouldn't have anyproblem with it...
Originally Posted by tkracing
i think 98-99 gs300 did not have an engine cover. you may get away with using an rmm stb with spacers??someone should chime in.
RMM stb???
Originally Posted by wringo
Here's a pic of Bluelex's old set up with it on his car with the same engine cover I have? I don't see what the problem would be!
It looks like adrian has the rubber ring on with the STB but its hard to tell in the pic? Well, that STB is 295.00 so we must be sure that it fits.. IMO i don't see what the problem would be either. There's no wa that 300 engine cover sits higher than the 400.. Is there?
Wringo... What are you going to do?
Tony
Tony
Wringo,
Given a choice between the two I would just remove the engine cover, the RMM brace clears the edfc motors and looks so damn nice, add a Prolex heat shield and maybe polish your intake.
If I remember right the 00-up gs3 with engine covers wouldn't clear the rmm strut bar. I think the 98-99's would clear it with an engine cover. Mine set up was a custom retro fit just to make it stay in place but still the RMM rubbed against it and pressed into the paint on the right corner for some reason. It cleared the rest of the cover and where it did press into the paint didn't matter cuz you could see it unless you removed the strut bar to look. I think your best answer it to look into small spacers like others have used to make them fit on their cars. you should have any issues. You aren't drifting your car. I think something minimal like a 5mm would clear the cover. I think it looks so much better with the cover than without.
