Help!! Odometer Lights Out.
Originally Posted by chabelo31
I Need Some Help My 2000 Lexus Gs ODOMETER Lights Went Bad Anybody Have An Idea How To Change Them.
what were or did you do when they went out ?
As TeflonGS said, reset the ecu...if you ever ran your battery down it will mess with some of the electronics in the car. All it takes is a reset and it usually fixes most of the problems.
Remove the negative battery wire for 15-20minutes and reconnect it. Then get in the car and see if the problem is still there. If it is, the wires behind the dash connecting to the speedometer might be loose. If none of those work, then the unit might be broken. It is very rare though.
hyn_stunna
Performance & Maintenance
11-28-07 11:49 AM
