Help APEXi S-AFC
In the wiring diagram it has throttle and air flow wires but in the harness has air flow output and air flow input wires. Which goes where?
Also it says the sensor type is HW13 where does this fit in?
you just have to tell it that when you are puting in the data, it has nothing to do with the installation.
I have a copy of the sheets for the US wiring diagrams and it says GS300 and GS400 use T10a as the wiring diagram.
Could someone with the S-AFC already clairify this? thanks
Pann,
I can't get the Throttle position to work neither! The
S-AFC wire manual doesn't indicate which color wire is used for the throttle position. I tryed all of them and none worked. I going to dyno tune my car, I guess I'm going to set the setting using the low throttle. Do you know which wire from the AFC is for throttle? If I get it to work I will let you know.
GS4K
sorry for late respond. If you connect the gray wire its will read the voltage from the throttle but doesn't show the throttle percentage.
Pann
Pann
AFC suppose work more efficiently with any intake, just as long their more air flow than the restricted stock box.
The yellow and white wires are the air sensor for the AFC module and look at diagram T 10-a for the wire from the ECU
