Transmission problem????
Originally Posted by Dx3
I don't think the solenoid has anything to do with it man. It is the new 3.76. That is why I got rid of mine - it would just hold gears and hit the rev limiter instead of shifting.
Jonny
Jonny
Mine seems to be shifting at the same point as before on WOT....about 6000-6200rpms.
Originally Posted by AZDesertGS
That wouldn't have anything to do with you being boosted.......would it???
Try stomping on it in first gear and bringing it all the way to redline and see if it will shift normally for you or hit your limiter.
Jonny
No, I had the 3.76 before I got boost and it was happening. After boost it got even worse so I got it out of there.
Jonny
Jonny
I have and it still shifts before redline about the 6-6200K mark.......Everything seems to be normal with off the line shifts and downshifts when I floor it on the highway. Just this occasional problem.
I also noticed today that I have lost about 3-4 mpg this last tankful.......anyone????
You might've gotten 24 mpg on the way to work this morning, but comparing your regular driving from before the LSD to your regular driving now show result with you losing a couple mpg.
I guess in this case, we gotta consistently pay to play
but hey the
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
EDIT:
I ran a search and came up with this for u. read the second page, others are documenting the mpg loss as well.
https://www.clublexus.com/forums/sho...t=lsd+mpg+loss
Originally Posted by GS42NV
the reason you lost 3-4 mpg is because of your LSD. The different gearing carries the car at a higher RPM consistently, therefore causing you to lose mpg. Its right in that 3-4 mpg range, so I would expect it to be permanent.
but hey the
off the line would make up for a couple mpg anyday of the week IMO.
EDIT:
but hey the
EDIT:
Well I have had 4 tanksfull so far so I know Im not losing 3-4 mpg......more like .5-1 mpg. I think I may had some bad gas with the bad mileage last tankful....
JoeV215
03-18-13 05:26 AM
