HR Spacers on, couldn't be happier. PICS
Purchased the 25mm spacers from Kaine last week. Got them yesterday and had to put them on right away. I am more than happy with the out come. The wheels I have on my lexus are off of a IS300. So any one looking to get those wheels for your GS spend the extra money and get the spacers.
After my first drive the car seems to handle better and the ride actually feels smoother. IS it just me? I don't know but my friend who helped me thought it drove smoothly as well. Putting them on was a piece of cake as well, no problems at all.
Before
After
Before
After
One more After
Before
After
Before
After
One more After
Originally Posted by phisig
How wide are those rims and tires?
Tires are 245/40
Pics I think tell it all about the fit. I tried to get lined up in the same spot when taking the after pictures so you could better tell the difference it made.
Originally Posted by Red Rover
Rims are 17*7 (I believe the stock GS wheels are 17*7.5, so this pushes them out 1/2 inch further than the stock rim)
Tires are 245/40
Tires are 245/40
It definately looks better, but I don't think I could trust spacers.
very interesting. I have 18x8 w/ +40 offset and going to put 15mm (front) and 25mm (back) for a sc430. tire size is 245/40 18.
it's a two seater (in reality) so I don't plan to carry heavy passenger loads so I'm not worried about that.
I believe I have the longer studs that came w/ it.
are there any other issues that should prevent me from doing this?
thanks for your input....
Northern California Regional Officer
These are some very , very old questions and an old established mod. This is not rocket science. Members have been using them reliably for years.
It's kinda funny, but I have seen a set of spacers get installed on one members car, and through time get sold on our classifieds and re-used by several other members over time.
I believe Jawnthen bought a set of spacers that were passed on about 3 times over a 4 year period on these forums. He recently sold them to another member !
Once someone get's wider aftermarket rims, these spacers are the first to go.
Key things to note:
1. Use a one inch (25mm) or less spacer with built in studs, so no issue with threads. Spacers that ar e 10mm or less should come with replaceable studs that are longer.
2. Purchase only quality spacers like from H & R , you are safe with a 1" spacer. Though there are some other good brands, this is the only brand I would recommend hands down. There are some cheap no name spacers out there that ARE dangerous.
3. Do a search for H & R spacers. Someone posted in the past few months, where to get them at a good price
4. Follow torque specifications for all the bolts.
Lexus (just as Toyota) has always undersized our factory wheel well spacing. Spacing out smaller width rims has always been a very nice cosmetic improvement. It should of come that way from the factory.
Key things to note:
Key things to note:
Key things to note:
I know that this question has been around for awhile and I looked a lot before I got these. I just wanted to post some pics cause I know that is the deciding factor for most people. Seems to me people never take many pics so I am always sure to take good care to get some nice before and after shots for every to enjoy.
Thanks for the comps
Red
Red
Red
You took some good shots which is very helpful to the new members who don't know or wanna know about this mod. Yea old mods never die, they just cycle through the forums every once in a while.
My input is intended to get people up to speed with the historical facts, and to minimize us from repetitvely beating up a very old dead horse.
Key things to note:
Key things to note:
I agree completely, as long as these have been around I'm suprised at all the scepticism, I have had two sets with no issues, H&R makes a quality product, the 25MM have the longer studs built in as well as hubcentric rings, if you are running stock wheels these will make your car look much more aggresive and improve handling because of the wider rear track.
Nice upgrade Red.
Another after pic.
Rubbing not a problem so far.
Had my first test last night with a car load of people. There was me 200lbs then there were 185lb, 165lb, 150lb, and 105lb in the car. The three lighter people were in the back but there still was no issue of any rubbing on the car. Went couple hundred miles over some good ole Missouri roads (not very friendly) and never heard or saw it rub once plus there was no signs of any rubbing after inspection.
All is good
Red
All is good
Red
