Any way to have all 3 lights on at once? Fog/Low/High
So, pretty much as the title suggests. I just did BananaGS's mod for the fog light switch, but it still shuts off when i hit the high beam. I have HID's in the Fogs, there is a Bi-xenon projector in the low beam housing, and the high beam is still halogen. So, anyone figured out a way? I'm going to try testing each individual wire in the dash later to see if i can bypass it. Hopefully someone has done this already so I won't have to test every wire in there...lol
Alrighty. I just have to wait till tonight. I was up the whole night working on my car...haven't slept yet I have HID foglights in my car, so I'm sure it will look nice
I finished a few mods: Rebuilt HID Projector mounts(involved completely taking it apart and redoing whole retrofit....very time consuming), foglight switch mod, and I also run a 4GA power cable to the trunk. I'm about to pick up some subs and amp today
Also, DJ Fergi. I'll post the reply to your PM here since I bet many of you will have trouble figuring it out the first time. I might re-write and take new pix of the DIY if BananaGS doesn't mind.
Anyways, check that the pin you pulled out is plugged back into the connector. I missed that step and I spent about 30mins connecting/reconnecting all the wires about 20 times until it finally hit me, that there was no signal going to the switch
EDIT: Oh yeah, I forgot to mention the most important thing...lol. I think I've figured out a way to wire the lights so all 3 will come on at the same time. I'm going to spend some time researching/experimenting today. Wish me luck
i would like to do know about how to wire it up so you can have all three if you want to as well... i did bananags's fog light mod and im happy with that..but id like to have the fogs completely independent to turn on and off as i wish, not when my highbeams want me to..i know its a safety feature to not blind other drivers, but when im on the road by myself and i want a LOT of light, i should be able to have it any way i want lol..so if you figure out an easier way bro let me know.... also want to hear some feedback from you after you install your stereo equip...my engine noise (whining you can hear from stereo speakers) gets worse when my hids are on...im wondering if its going to be even more annoying with a second set of HIDs now since id like to put them in my fogs.... the whole situation sucks, considering i have all high end crap in my car, eclipse navi/dvd/cd headunit, all ads speakers inside, all eclipse amps powering everything, monstercable wiring throughout, optima battery, monstercaps, bla bla bla.... some believe its an issue with this model deck, but i think it all breaks down to improper wiring..either way id like to know if you experience any problems like mine..
Please note I didn't to this on a GS.
I cut the fog light wire from the light switch and jumped it to the parking lamps. That way the fogs could be on with parking lamps, high, or low. This way they also couldn't be left on alone. Then under the hood I cut the feed to the fogs and added a relay. The relay was turned on and off by the fog light switch and the power to the fogs was powered by the relay with an inline fuse. I was told by the dealership to use the relay because the parking lamp wires and such couldn't handle the draw the fogs would create.
Hope this helps.
Hope this helps.
Originally Posted by Lexbox
Do you have high quality RCA's? Cheap RCA's can induce engine noise. Also make sure the power wire and RCA's are as far apart as possible. And also try to make sure all of your ground in your stereo are grounded at the same point. If not and easy way to fix it is to unhook all grounds and get a 0guage ground going with a non-fused distribution block and ground everything to the block. Centralized grounding is good.
im in the process of rechecking the grounds bro, ill be able to spend more time on it now that tax seasons coming to the last few days..more free time soon! but yeah all the rcas i have whatever the best monstercable sells are, they were expensive...not saying price=quality but i have always used monstercable top notch stuff in my other rides and never had an issue...i know they are not all grounded out to a distribution block...maybe that would help...and i do want to have it re wired because i know they did a rush job on the damn wiring and ive pulled up the back seat and seen that it was way to close to eachother..i tried to separate it SOME but it needs to be redone...also been told that the preamp something on the back of some of these eclipse navi decks (i have one of the dvd navi/cd/fm/am/mp3 ones from last year or the year before) were too low of a voltage output or two high? i cant remember i have to get the whole thing re done and maybe the deck replaced too..it sucks having such a nice setup getting destroyed by engine noise...its embarrassing and obnoxious to listen to all the time... oh ps JEFF sorry didnt mean to bust into your thread with my question..
Hope this helps.
Hope this helps.
Originally Posted by Neo
JeffTsai,
Are you giving up the high beam option (and making it an extra low) or are you planning to run highs all the time? I am not sure if I like either option.
I haven't had a chance to test this yet becuase I was working on my subs and amps all day. I should be able to try the 3 beam mod tomorrow
exclusive matchup
if you just want to have all 3 on together for a little while, just put the high beam is flash mode, that way all 3 lights are on. only if you flip on the high beam permanently that the fogs will turn off
i don't know, personally i don't see the point of keeping all 3 on except if you want 2 secs of flash or so. and i would definitely suggest against driving with all 3 on
Another benefit of an Asian GS , i can have all lights on at the same time
Why ? I dont see what harm fog lights can do
exclusive matchup
It is not the fogs. I can't speak for Henry but I would rather not be on the receiving end of a car driving with highs on at all times.
but having highs on when driving, that's just bad..... i HATE people when they drive behind me with highs on
yup, that's what i was saying. whenever my low beams are on, my fogs are on. that's not a problem, and it's legal
mistale107
09-12-10 01:08 PM
