3000 Miles in my 99 Lexus.. First impressions and Observations.
Well, I have finally put 3000 Miles on my 99 Lexus GS400. I bought it in January with 27.7k miles on it. The first thing I did was change the oil, differential, and drain and filled the tranny. I also added a K&N panel filter and reset the ECU, since an old lady owned this car.
Well, I love this car!! I came from a 1997 Taurus SHO, which I though was a beast, but with it's transmission woes I ditched it. Words can't compare how much better the Lexus is than the SHO. The ride and engine is so quiet that when I drive my wife's Nissan Altima, while quieter than a lot of cars, I stil get irritated by the loud 4 banger in it. These are my comparisons and OPINIONS of my GS400 vs Tausus SHO
Stock Suspension - Tausus SHO is much better.
Sound System (My Lexus doesn't have the Nakamichi) - Taurus Mach system better
Quality on interior - Lexus by Far, expecially the leather compared to the Taurus's Leather
Ride quality (Smoothness to Michigan Road) - Lexus by far
Reliability - Lexus no question
Options - Lexus
One thing I did like better in the Taurus was the Automatic Headlights had a sensitivity setting for turning the headlights on.
Performance - Lexus of course
Okay, here are some observations from my first 3000 miles.
Overall, I am very pleased with this car. I would not go back to an SHO if a gun was put to my head.
Options - Lexus
- The Lexus does have a floating feeling, but with Michigan roads, I will have to deal with it. My SHO had a firm suspension but the roads were killing me.
- When I shift into drive the car seems to squat or lower in the rear. Is this normal?
- When I shift between Park, Reverse, Neutral, and drive the car seem to jump a little. Is this normal.
- From launch the car seem to hesitate until it shifts into gear 2 then I can feel some pickup. Is this normal?
- The steering feels weird. The car seems to wonder in the lane.
Originally Posted by nlspears
he [*]When I shift into drive the car seems to squat or lower in the rear. Is this normal?[*]When I shift between Park, Reverse, Neutral, and drive the car seem to jump a little. Is this normal.
[*]From launch the car seem to hesitate until it shifts into gear 2 then I can feel some pickup. Is this normal?
[*]The steering feels weird. The car seems to wonder in the lane.[/list]
Glad you enjoyed your first 3k miles... Numbers 4 and 5 seem about right... under your observation list but a GS itsn't even in the same catagory as a SHO.. I think the thing i hate the most is the car seems to wonder when your driving straight... VEry weird.. but if thats my only complaint than I'm doing pretty good..
That is such a verry low mileage car you bought there
Options - Lexus
I'm not sure if this is what you meant, BUT the lexus has automatic headlights that turn on when it gets dark. You have to set the left headlight switch to "AUTO". You can cover those black nickel-size bumps by the front windshield with a piece of paper and you'll see the light turn on automatically.
[*]When I shift between Park, Reverse, Neutral, and drive the car seem to jump a little. Is this normal?
I think this is common in most cars that I've faced. After parking and before letting go of the brake, I depress the foot brake then shift into park. This locks the car rather than your transmission engage the car into park. There was thread that discussed about this.
I think this is the lag that the drive by the wire system . Someone more knowledgeable can explain that.
I think that it's more of the whole suspensions where Lexus uses softer components (bushings) to give it that smooth feel, really good for soaking up bumps and bruises but makes the whole car feel too loose.
If it's pulling to the left or right when driving then it could be the alignment.
Originally Posted by GS3Tek
Welcome you to CL and congrats on your new GS
Options - Lexus
Options - Lexus
Yeah, I know the Lexus has an automatic setting. What I meant is the SHO had a sensitivity switch where you can adjust how dark it must be before the headlights turn on.
No, the car doesn't pull to the left or right, just wonders, but I guess that's normal. I did just empty out my steering system today and put tranny fluid in it. I don't know what was in it but it wan't red, so I drained it out of the resevoir and steering rack. I will see how the steering feels now.
I know the SHO isn't in the same class. I was just comparing it since that was my previous car.
Thanks for the welcome guys!!
I think any rwd car with a powerful motor will do that. With an automatic tranny, the rear wheels are pushing foward while the car is stationary when you are in drive. Even though the car is not moving, the suspension is being pushed downwards due to the force from the torque converter at idle rpm. Im sure any RWD car will have this same symptom. It is more pronounced when you gas/brake getting ready for a launch at the light.
That's what I figured, since I am used to driving front wheel drive cars I didn't know what to expect.
omegagavin
05-20-04 07:20 PM
