what kind of tape to use?
i think some other people have had this problem in the past, and i'm sure you guys can point me in the right direction. i got an l-sportline roof spoiler recently, but now the ends are starting to come up. the double-sided tape the shop used isn't holding that well. any recommendations on the proper tape to use? thanks all
Originally Posted by rominl
yup the 3m industrial double sided tape, that's the one you want
exclusive matchup
Originally Posted by JeffTsai
Thats what I thought you guys were talking about, but isnt that stuff a bit thick? It's not horrible, but its still 1/16inch thick or so. It is a noticible gap if you look at it.
Yes, its a very bad idea...lol. The superglue will most likely eat thru the paint layers to bond, thus if you ever try to remove the spoiler, the roof will need to be repainted. Second of all, if you plan on using it anyway, make sure to mask off all the areas since superglue has this white gunk it deposits around where it dries. If you really want to go with the glue route, your best bet is to use epoxy. Epoxy will be pretty much permanent mounting since it bonds stronger than superglue. With epoxy there is no gap at all and none of the residue of superglue. Epoxy is also much more shock resistant than superglue. I think the best option is probably to use the mounting tape. Since rominl said its not so noticible. The tape route will allow the spoiler to be removed later on without damage to the roof.
smokyis350
03-14-14 02:24 PM
