Fluid Intervals?
Fluid Intervals?
I was wondering what mileage interval I need to change the following:
coolant
power steering
brake
transmission
differential
am i missing any fluids? thanks
coolant
power steering
brake
transmission
differential
When I got my 90K I just got all the fluids, except steering, flushed as a precaution. The dealership said power steering was unnecessary unless it was contaminated...they just added conditioner.
I have changed my power steering fluid by siphoning out the fluid in the reservoir and refilling with Dexron III. This was repeated once a month for a year to exchange almost all of it.
I also siphon out the windsheild washer fluid and replace it once a year. I hardly use the washer; the fluid gets stale.
Super Moderator
I have been Valvoline Synpower PSF for quite a few years since until recently I couldn't get Mobil 1 ATF, but at least one other buddy has used Redline PSF for years and no issues.
ok i'm about to do a power flush on my differential, transmission and i think that's it.. do i need to flush any other fluids? i was gonna do coolant but i had it drained and re-filled at my 90k service and i know it doesn't need to be flushed because it already has the toyota red coolant, right? the rest i'm only flushing because i'm changing everything to synthetic..
so which fluids do i need to get flushed and does anyone have the amount of fluids i need to get it all done? thanks
No need to power flush the differential. Gravity is all you need.
thanks jonathan - weird - i just found out from reading your post while i was on the phone with my dealer haha..
does anyone know how much fluid i need to power flush and refill:
brake
power steering
transmission
for differential - do i just change it like oil? drain the old and put in the new?
the coolant - they already drained and refilled it with toyota red at my 90k service, when do i need to do it again?
thanks
brake
power steering
transmission
thanks
Yea for differential make sure you can open the inlet plug first before you proceed, since alot of people tend to have problems with that bolt. And make sure you dont over fill since, well fluid dynamics 101
Originally Posted by Kharizma
i was going to put in royal purple 75w140 - is that wrong?
Super Moderator
I recently switched out to 75W90 Royal Purple in my RX, but the distributor here also offered me 75W140. We actually bought some as well, but for big trucks that my uncle fixes.
RuninRoach
12-04-14 05:13 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
02-12-09 10:05 AM
