01 430 Navi Diagnostic Mode
Hi, can anyone please help me get into the diagnostic mode on my 01 430 with navi. This is what I do.
I turn the car on, hold the climate and audio button, turn the parking lights on and off 3 to 4 times.
I get a menu that is Japanesse. I have 2 buttons on the bottom right on the screen. I press the right one. And it does the self check again. I press the one next to it on the left, and it switches to all Japanesse.
I would like to get to the part that I can adjust settings and get to the audio menu.
I tried searching, and cannot find anything better. Someone please, please help me. I would like to test this out. Thanks.
Red
Push the menu button on the navi, then press the DVD button...
Tap top left of navi screen, bottom left, top left, bottom left, then bottom right. You should get into the setup area.
lol, are you serious? This sounds like some super mario unlimited life trick.
Ok, press the info then the display button. Then tap the upper left screen and right above the contrast in the lower left corner of the screen, do it quickly about 3 times, but not super fast. It'll dump you into the diagnostic menu, which you wanted.
Originally Posted by oohpapi44
SlickGT,
I'm just curious, what are you trying to do in diagnostic mode?
Would it be the same 'code' that allows you to input address while driving?
thanx a lot
ill go try it out soon
