Oil Pan
Oil Pan
i may have stripped my oil pan where drain plug goes. i tightened the drain plug screw, it got tight...not super tight so i gave it a harder tug and it started to spin but not tighten anymore. i turned it a few times hoping it would tighten up but it didnt. could it be the bolt or do you guys think i need a new pan? is the oil pan the same as the one on the toyota supra since its the same motor?
my gf's car had a striped oil pan.... before i went out and got a replacement pan for her, i just bought a new bolt and slowly screwed it in all the way and then back out...did that a couple of times
then i used a napkin and fed it into the hole played with it for a little...then pour some oil to flush out any more shavings that were inside.
try that first before getting a new pan.
How is the condiction of the oil pan plug seal?
Without using a plug seal, or using a worn one, causes the plug to bottom in the pan. If one checks the plug close, there are no threads at the plug head; so it tends to strip out the pan nut inside the pan if forced. This is because the seal also acts as a spacer to keep the plug head from bottoming, thus using good plug thread.
Your options are to remove the pan to retap it or use a universal rubber screw stopper as a temporary fix. Use care not to migrate any shavings or old trreads inside the pan.
does anyone know the thread size? im going to see if a new plug will do the trick. if not, i guess im going to have to drop the pan. where can i get it retapped or should i do it myself?
First, expect problem getting the drain bolt out. Once the trailing edge thereads get messed up, it is very difficult to get the plug out.
Once you have the bolt out, take it to pep boys or other shops and you will see a full option of next size bolts in fine and regular threads. Buy a tap to match the threads and a drill bit (if required) to match the bore.
Next is the choice of tapping with the pan on or off. With pan on, apply grease liberally on the tap and cut new threads. Puor a qt of oil and let it drain out to flush metal particles.
Pan off is better [recomended] {to take the bolt out maybe you will have to take the pan off}. Tap and and clean the pan. Buy FIPG paste to seat and seal the pan. Torque the pan bolts [use toque wrench ].
Wait 2 hrs and fill oil.
Salim
Salim
GSLexTexas
01-17-17 09:20 PM
