Before Installation
Before Installation
So I just got my Tein CS (Thanks TM Engineering) and im about to have it installed this week , can anyone give me any pointers or things to watch out for so i can tell the mechanic whos going to install it ?
Oh and i want a 1" drop front and 0.75" back , but i dont know how many threads im supposed to have
I'd really appreciate ANY help !!!
Thanks in advance .
Thanks in advance .
Like Morris said it is trial and error. Really no way to look at the threads and know what specific amount of turns to get you the desired height. You just have to set it, lower it and look at it on the ground, then adjust as needed. You wont get it on the first try unless you are extremely lucky.
I'm in the same boat but with Bilsteins. Are there any sensors or wiring that a mechanic should be fore warned about before installing coil overs? I read horror stories about rear suspension mods pinching VSC wiring causing problems.
Former Vendor
AJ - be really honest with yourself and figure out if you want a soft - luxury feeling ride before you put the Tein CS on your car... Think LS430 soft...
i swapped from the bilstein/eibach combo and most likely wouldn't do it again because it offered a sportier ride (think bmw ish) and it gave me more confidence going into corners than the tein CS setup.
if you want a REALLY posh ride this is the setup to have. if you want a ride where you feel more direct response from the road then reconsider before you put these in.
^I never drove an LS but i did drive an S series and a 7 series and they are great So yes , i definitely want a soft ride quick Q , how do i adjust the damper on the rear coil ?
The dampening adjustment **** sits on top of the coilovers. Turn it all the way (clicks) to the right and then 10 clicks back to the left to get to the 'standard' setting I believe.
Congrats on your purchase. The CS is on the soft side and is not as confident inspiring around the twisties like other setups I've felt. After the install, drive the car around the block so the coilovers can settle in a bit for final height adjustment. Wait one week before you get an alignment. You "may" need more than one alignment at a later date, as the coilovers settle in.
Originally Posted by oohpapi44
No, it's a very simple install, if you need to give guidance to your mechanic/installer, it may be time to switch to another mechanic/installer...
Tein lists a starting point in the manual. if you raise the perches about 1/4 inch from the stock Tein setting, you should get the drop you are looking for. that's what I did.
