What are the exact measurements of the trunk key hole?
Originally Posted by Hameed
Did your install require any metal cutting Lexbox?
My questions is how do you secure the camera in the hole because it is not a snug fit the stock key cylinder mounts in an oval hole about 23mm x 35mm.
Secondly, when you unscrew your lock assembly how do you secure it so that it will still function w/ the inside lever or remote. It looks like if you move the key cylinder to far form the hole the latch won't activate smoothly.???
If you have not taken yours out yet I can shoot some pics.
EV ftw!!!
Originally Posted by ebruce2
OK Hameed, you brought the pressure on yourself now bro.... we are gonna expect a nice DIY writeup for this project.
Originally Posted by GILLEXUS
Did you ever find out the the measurements you wee looking for.
I just took my trunk panel apart and puled out the key latch. I have thought about doing putting a camera in but was never able to get any one tat had any pic of how they installed their camera. My questions is how do you secure the camera in the hole because it is not a snug fit the stock key cylinder mounts in an oval hole about 23mm x 35mm.
Hopefully I will be able to fit this in without any major issues.
Hameed, After looking at it a the lock assembly again , there is no problem leaving the locking mechanisim in . I was wrong I thought that the wire going to the key lock cycinder was was what trigered it for the inside latch. That wire must be for the alarm system.
check out the pic of the key hole & you see what I mean by it is oval 23ish mm x 35mm The camera you are geting will work because ( if your getting the smaller one) the main barrel part is 24mm and the end cap is 30mm. The stock lock is ( the barrel section) 23mmx 57mm.
back side of lock
trunk bar off see oval shape of key hole
lock cylinder out
back of key hole
See how lock sticks out at an angle
back side of lock
lock cylinder out
back of key hole
EV ftw!!!
Thanks Gillexus for posting up those pics! ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
So taking out the lock cylinder was just simply a matter of taking out those two 10mm bolts? And I guess the alarm wire stays there?
I assume the wire goest ot the alarm system that is the only thing I can think it can it is. sets off te alarm if the trunk is opened via th elock when it is set ?? more pics
Here is a camera I thought about looks decent goes on top of license plate by Vizualogic. I only found one place selling it w/o the monitor kit for $245.
![](https://www.clublexus.com/gallery/data/500/versa_mount-hi_Medium_.jpg)
This one looks alright. this route you don't have to mess w/ trunk lock but it does not look as nice and low key as the key hole camera
Originally Posted by GS300Rich
subscribing to this thread. I have wanted to do this for a while and really want to do it myself. Great info so far ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I was really curious as to what was behind the trunk key. so I just decided finally see for sure.
I'll see what Hameed comes up wtih as for as securing his camera in place.
Be carefull taking the emergency trunk lever molding off. I almost broke it trying to pry it off. I'll snap some pics of it . It really helps to see how the clips are facing on it first.
EV ftw!!!
Same here I don't even have my video system in yet but a bought a bullet style camera awhile bace because I wanted to do this. every time I post up question asking how people did there they did not have any pics or some one else did it for them.
Obviously the trunk lever still has to stay there after the camera is installed otherwise how would one open the trunk? Hmmmm..... this is not as straightforward as I thought it would be.
Thanks Gillexus, those are some excellent pics you posted up.
EV ftw!!!
Originally Posted by Lexbox
This is VERY straightforward actually. You dont need the trunk lever. Once the camera is installed you simply hit the button on your remote and all is well.
What about the button in the car itself. Would that still work?
I assure you it will take longer to run the wires for the camera than it will actually take to mount and aim the camera.
EV ftw!!!
Of course it still works. There are two mechanisms responsible for opening the trunk. An electronic release, which is put to use when you hit the remote button or pull the button from inside the cabin. And secondly, the old school bar method that is only used when you turn the key from the locking mechanism. You can equate it to our throttle cable setup. We have drive by wire but also a manual throttle cable as a backup. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
How did you secure your camera in the key hole? did you make a metal braket or do you have any pics that you can share?
