Help! changing out the door lock actuator
My door lock actuator went out on the Passenger side Front and I plan on changing it out myself. What I need is someone out there that knows the proper proceedure for taking the door pannels off. I don't want to screwing things up! I would appreciate the help.
Its not that hard..i've done it numerous times... if you do a search you will find several threads on it.
https://www.clublexus.com/forums/sho...ont+door+panel
this one is courtesy of bananags...alot of tutorials here![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
http://lexusmodz.netfirms.com/
here you go with the locations of the screws....
there is one which isn't mention which is inside the bottom pocket of the door just look up and you will see it.
Vlad_Stein
02-08-10 09:25 AM
